Wondering if a balance right, left function is on the remote and available from the
push select on the encoder?
I've been looking at Arduino's for about 5 years but never did anything with them.
Anyone know if there is a larger, code compatible, version that would make
expansion easier, say rather than running multiple boards?
Wondering if the current version of the Apple remote still works well? Anything
better for a bit more money?
Hey everybody,
So it took me a while and a lot of learning along the way, but tonight I finally turned it on, biased, measured ldr values, edited the Arduino file, compiled, uploaded, calibrated and success! Everything seems to be working the way it should. Woohoo! I just have one question though: is 123 ohms too high for one the ldrs? Here's what I got on all four: RSH: 105, RSE: 70, LSH: 123, LSE: 75. So LSH is higher than the 120 ohm max in the build guide. Also, when biasing that ldr it was hard to get it to 700k ohms. At first it was fairly low so I gave the trimpot a few quick turns thinking it would react like the first ldr but it just blew past 700kohm and kept going way above 1Mohm before I could bring it back. Could I have damaged it somehow by letting it go so high? I have one more ldr left that I could use as a replacement. I just don't like desoldering much. Thanks for any advice. And thanks again to Vincent77. Great project.
If it completed calibration OK it should be fine.
Is this what you were looking for?Picture of these somewhere showing size and mounting?
Thanks all,
Any other boards?
Sent from my ZTE A2017G using Tapatalk
What kind of relay are you using on that board ?
I've used Panasonic AGQ21012 and it doesn't work.
I can select a different input and see a difference on the lcd and the voltage i measure changing but i hear no relay clicking.
Ronny
Ronny
First check the power to the relay power connector is of a voltage suitable to drive the relays and that it has the correct polarity.
Check the inputs and outputs around the IC1 (ULN2003) relay driver which you should see toggle as you change inputs etc.
Is this what you were looking for?![]()
I have one AIO PCB left with relays and 5LN01C soldered on bottom side for sale. PM me if interested.
Hi guys,
I'm sure these questions have been answered somewhere in this thread already but I'm having a hard time finding exactly what I need: mostly because I'm super new to Arduino code. So any help would be appreciated.
I got my Arduino LDR selector working like a charm with my DCB1. Thanks again to everyone. I just realized though that since I'm using the DCB1 selector function I don't really need the LCD screen for the time being except to see the volume. Here are my questions:
1. Is it OK to run without the LCD for now?
2. Is there a way to change the code so it automatically resets to zero volume when I shut down?
3. I did notice a relay click that comes through my speakers when it goes from 1 to zero or zero to 1. is there any way to fix that?
4. When I was testing the 3 voltage outputs on the PSU I was using the PCB ground point(by C3) as my negative. +R and +D were fine but +A was zero vdc. However when measured from the negative spot at the +A outlet, voltage was correct. I just wanted to make sure that was OK.
5. I'm using the Vincent77's original firmware. Should I be using Wineds's improved firmware? Other than the relay click the original seems to be working well for me.
6. If I do change firmware do I need to recalibrate?
Thanks in advance
Thanks in advance
Hi guys,
1. Is it OK to run without the LCD for now? Yes
Yes you could try setting the volume to 0 in the power off code. Do a search for "#pragma region powerOff" to get you to the right spot and add the line "setVolume(0);" This assumes your PSU has enough capacity in the smoothing caps to allow the Arduino write the info as the power fades
Not sure without affecting the signal path by adding additional components. I get the same. Part of the problem is that the LDRs do not drop to 0 ohms more like 50-80 and so the relay causes the jump as it shorts to ground. Do you need the mute relay? ie is vol 01 not enough?
It must be OK as the unit is working but as the ground is shared between all the power supplies you should have seen the A+ voltage.
Stick with what works for you.
It will normally prompt you if you make code changes that need recalibration such as the number of steps impedence etc. If you make any component changes I would recommend recalibrating. And on that point disconnect the inputs and outputs when making the calibration measurments.
Thanks in advance
Gary
Thanks so much Gary. That really helps. I think I'll just live with the mute click. It's not that loud. Thanks again.
Yes that picture helps.
You have one more of the All-in-One board that I bought?
Is there a specific build thread for this board?
Anyone implemented R-L balance control?
I'm happy to report that my oled code works with SH1106 based displays too, like the cheap 1.3" ones from aliexpress:
https://www.aliexpress.com/item/1PC...32777848832.html?spm=2114.13010608.0.0.dawDVJ
With one slight modification:
// oled.begin(&Adafruit128x64, I2C_ADDRESS);
oled.begin(&SH1106_128x64, I2C_ADDRESS);
0.96" is too small but this one might be quite usable.
I still have few. This is the only thread afaik, no balance.Yes that picture helps.
hi,
I built an All-In-One board and embedded it in my diy amp (a MyRef Fremen Edition).
It works fine but when i turn on the amp (amp modules and ldr board share the same on/off switch) I hear a buzz and then a bump. after that everything seems to work properly.
I've done a bit of debug and I found that the buzz is audible until the procedure SetPinModes() is executed . The execution of this procedure causes the buzz to cease, then the bump, and after that the noise is over and the welcome message appears on the display.
Any suggestion about how to troubleshoot this?
Thank you.
Filippo
Thank you.
Filippo
hi,
Thank you.
Filippo
You need to delay the start of your amp somehow. Maybe implement a 12v trigger on your amp and use one of the All-In-One boards relays to activate it.
OT here...PB2, have you ever been told you look a lot like our own NASCAR guru Darrell Waltrip?
hi,
Thank you.
Filippo
The "GND" pin on the power supply module should be wired to the chassis or to ground/earth.
thank you for the suggestions.
About the ground connection: i created a ground hub attached to the chassis and connected to the ground wire coming from the power supply socket. Ground wires from trafos, MyRef FE boards and PS of the LDR controller are connected to this hub to implement a ground "star" configuration.
So PS board is properly connected to ground, according to nikos suggestion. Anyway I'll double check solders and connections. So my doubt regarding grounding is: could I have created a sort of "ground loop" inside my device causing that buzz?
On the other side, Wineds suggests to set up a mechanism to delay the turning-on of the amp modules. This implies (according to my understanding) that the buzz&bump is pretty normal when the controller comes up and that the amp modules should be turned on only when the 'boot' phase is completed and the system is stable. This implies too that:
- I haven't done anything wrong with the circuitry, grounding, etc. 🙂
- I can stop to check here and there to find bad solders and mistakes 🙂))
- Other people experienced the same issue
- I've just to go ahead and implement the delay mechanism.
Can anyone confirm or not these assumptions?
Thank you for your patience.
Best regards,
Filippo
Best regards,
Filippo
Hi Filippo,
I'm still a newbie at this so I'm not sure if this helps but here goes. I am in the process of adding the LDR attenuator to my DCB1 preamp. My amp is an F5. I added the DIY audiostore speaker turn on delay protection board to the F5. It protects the speakers from any stray DC current but it also has two relays, 5 or 12 volt, that kick in after about 5 seconds, thus "eliminating any nasty thumps that you hear on your speakers". To power it you can add another small 12VAC or 24VAC transformer or, like I did, grab the 24VDC from the F5's PSU. From what I understand it will work with both AC and DC. Works like a charm for me; I turn the amp on and about 5 sec later, "Click". That said I don't have everything in one enclosure like yours and I'm not sure if you need the DC protection.
- Analog Line Level
- Arduino based LDR volume and source selection controller
