Over my Pay Grade but I wish you the best.
Anything in the schematic looking like it won't take the higher voltage?
What voltage is the stock wall-wart? I'm up against a similar problem right now with a stereo piece WW is 12v 2a but I'd love to change to 8x Alkalines for experiment......Should work, right?
Looks like I also need to build an ACA - I got such a nice aluminum chassis. 0.5m radiators (consists of two parts - can be placed on both sides possible). The decorative front, side and top wood panels still need to be cut, but the chassis and radiators look suitable for ACA. I think it will be dual mono.
Where's 2SK170/LSK170?
I just checked the store and they are in stock:
Linear Systems Matched JFETs – diyAudio Store
quads are showing available but pairs aren't. punkydawgs shows the 2SK170 on ebay and that is supposed to be a good source
matching jfets
a 0-20 ma current meter like this one puts you in business....https://shopee.ph/product/238365398/4626734896
Four ohm loading will not harm the ACA but it will lower both the maximum available output voltage and it will also lower any given signal voltage at the output terminals more than would an 8 ohm load because of the high-ish output impedance of the ACA.
What matters most is the impedance curve of the 4 ohm speaker because it is the peaks and troughs of that curve that will alter the voltage output of the ACA vs frequency.
The ACA runs hottest when it is idling with no signal.
- Amp Camp Amp - ACA
