Alpha Nirvana 39w 8ohm Class A Amp
My 2 cents worth what worked for me, First big fans go slower and provide more air, true, But what I found was at a slow speed there noise was a variable low pitch noise although quieter but more irritating and lower frequency which seem to reverb across room a bit like low bass dose, so have 50-80mm running slow enough to keep temperature controlled at the level you want, smaller vans which have a higher pitch sound that can be heard between tracks etc, so I removed metal top and placed a pillow as lid all sound gone as pillow absorbed sound so design a sound absorbing case there a things like what goes under bonnets of car etc that absorbent of engine noise .
Just my 2 cents worth.
Hello,
I seem to have read something in an old post in this thread, about mounting two fans in the refrigerator. Although it is somewhat exaggerated by the type of application and heat to evacuate, the operating time of the fans will be short and running at a few rpm, they still make less noise ... I am not sure either.
Greetings
Vunce, Yes I don't believe Noctua fans are as quite as there rating claims, Ive tested that out with a really old fan out of a old desktop computer nothing fancy about it,but quieter than my Noctua 80mm with the added cable.
If you want it really quite do what Nelson Pass dose use heatsink you cant fault the master, However I think what X is doing is amazing and more appealing to the eye than a bland looking heatsink with 0 db noise.
No pillow needed LOL. That would be a fire hazard!
The Noctua’s are silent. Really - you need to get the right ones though. The ones I use, have all sorts of aerodynamic tricks on the blades and housings. Sort of like F1 CAD design by CFD. It would not surprise me if Noctua’s are a subsidiary of RedBull F1 racing or started by one of their former aerodynamicist as both are in Austria. They have about 30 aerodynamic patents on the fans to make it silent. It’s all wind tunnel research and computational fluid dynamics (CFD).
To keep it truly silent, it needs to run at about 50% of its rated speed. So if it can’t cool the load at half speed the get a bigger unit or more fans. But with the PWM controller speed adjustment pot set to low and the dip switch set to not increase speed unless really hot. The claimed dB level on mine are typically 31dB and I believe it. With my ear 5 inches away I cannot tell it is spinning.
Here is one of the ones use:
Noctua NF-A9 PWM, Premium Quiet Fan, 4-Pin (92mm, Brown) https://www.amazon.com/dp/B00RUZ059...abc_RY2SERMHFWFHR6949GZD?_encoding=UTF8&psc=1
Also this one:
Noctua NF-A12x25 PWM, Premium Quiet Fan, 4-Pin (120mm, Brown) https://www.amazon.com/dp/B07C5VG64...abc_AQK6FTY38BKFGCNN62XB?_encoding=UTF8&psc=1
Notice all the ridges on the blades
Almost done
Well I tried to print some decals but the laser printer would not accept the decal paper stock. So I will move these to the living room and begin test
