Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
I see also 33pf smd for compensation,different values according to schematic,are these ok ?
You can try 33pF or 36pF, smaller if you can do it and not get oscillation. I have 36pF in silver mica but only 33pF in NP0 SMT. Both can work. You might even try smaller 28pF and get away with it. Hugh says best to use silver mica for sound quality. NP0 may measure lower distortion but silver mica probably best for SQ.
Ditto, X, your dedication to the forum is incredible. I joined DIYaudio in Sep 2001 and have only 5,600 posts, almost 25 less than you.
I guess it is testimony to your amazing energy and your willingness to help others...
Hugh
Thank you, Hugh (and all the folks above) for the kind words. It's been a great community to be a part of and to have so many people I now know from all over the world. It seems like any place I travel to now, i can meet up with someone from DIYA for a cup of coffee/beer or a listening session. 🙂
I have 2 pieces only 33pf Mica.
How critical is the 0.12ohm resistor?
Is it ok to use 0.1ohm for R132?
The pots are optional, just install the resistors and no pots. This amp doesn’t need any pots as it is adjustment free. Set R105 pot at 1050R or use 1k and 47R in series - again, no pot needed on this amp. You should look in the GB thread for more build tips as almost all of these questions have been answered there.
Aksa Lender P-mos Hybrid Aleph (ALPHA) Class A Amp GB
Thanks guys but this is tested already!
Two variable bench power supplies used at first start up.
+/-21v , 1.8A idle current.
It is singing nice!
I have listen only for a few minutes as i feel very tired.
