I measured an RCA 6JD5 tube here (Beam Triode, no g2 ) and got:
Cpg1 6 pF
Cpg3 10.2 pF
Cg3g1 8.5 pF
Datasheet says Cag1 1.7 pF
Without grid 2, there is no shielding from that. Obviously the 6 pF measured is too high. So I calc'd g3 shielding of g1: 1/(1/10.2 + 1/8.5) = 4.636 pF shielding.
Net result is then 6 - 4.636 = 1.3636 pF a little too low compared to 1.7 pF official Cag.
This would make one think that a g3 beam forming plate (giving some more shielding) needs to be considered for the Beam Power Pentode also, but that would take the calc'd Cag1 much too low. Got me.
There is a problem due to capacitances out to the support rods and beam plate that are not in the beam path. So g3 is likely adding some extraneous capacitance between plate and g1 as well as providing some shielding effect. No way to split that up except by an actual ground potential on it, as used by RDH4. Two lead C meters won't do that.
Cpg1 6 pF
Cpg3 10.2 pF
Cg3g1 8.5 pF
I think I've figured out how to do this with just a 2 lead meter. Take the 6JD5. Cpg3 is 10.2 pf and Cg3g1 is 8.5 pF. Now to get a ground potential at g3 (1/2 the meter AC excitation on each side's C) the two capacitances would need to be equal. So use the lower common capacitance of 8.5 pF (the remaining 10.2 - 8.5 = 1.7 pF would just be shorted out in real operation by the actual ground) for computing the shielding effect. So now 6pF - (1/8.5 + 1/8.5) = 1.75 pF
Just about on the 1.7 pF datasheet spec.
Should be able to apply this fix to the pentode case as well, but the calc's are going to be real messy when considering g2 and g3 are shielding each others effect's some.
A revision of: effective Cag1 = measured_Cag1 - ( Cag3 series [ Cg3g1 - (Cg3g2 series Cg2g1 ) ] ) - (Cg2g1 series [ Cag2 - (Cg3g2 series Cag3) ] )
The usual Beam Triodes are just a standard Beam Pentode with the grid 2 left out. Holes for g2 support rods are still in the mica insulators. The other parts are identical.
The 21HB5A (once on the old $1 list) should give you a 6HS5 if you pull g2 out. I'll take the 21HB5A. A very nice tube.
Pardon me, here's a side question: As I only know the way HV regulation in CTV's was done in Europe more than half a century ago (by a »ballast« triode), while the American way of achieving it on the flyback tranny's primary side is absolutely unknown to me, I'd like to see a typical schematics to understand it. Maybe even as a PM. Thank you!
Best regards!
Best regards!
George (Tubelab.com) is knowledgeable on that. I've seen his explanation about TV pulse regulators a couple of times here. 6/17KV6 was a common pulse regulator tube, but not as HV as the Beam Triodes. The 6/17KV6 Beam Pentode is a perfectly fine tube for audio too by the way, with no plate cap. But uses the dreaded Novar base (hardly any sockets around).
Having slept on the pentode Cag1 problem, I now have a trivially simple measurement that gives spot on results with a 2 lead C meter.
Going back to the 17KV6A regulator Beam Pentode.
Tying g2 and g3 together. measure the C from g2g3 to the plate and again to g1. (using touch/no touch difference method)
g2g3-p 7.4 pF
g2g3-g1 12.7 pF
and from before: p-g1 with other electrodes floating 4.3 pF
Now take the lower of g2g3-p (7.4pF) and g2g3-g1 (12.7pF), so 7.4 pF
Divide that by 2 and subtract from p-g1 so 4.3 - 3.7 = 0.6 pF
Which agrees EXACTLY with the datasheet 0.6 pF
The reason this works is:
to get ground potential (half way between the meter + and - excitations), requires equal cap from g2g3 to both p and g1. The extra (12.7 -7.4) cap at g2g3-g1 is just causing screening current to ground in operation. So we are left with 7.4 pF from g2g3 to p and 7.4 pF from g2g3 to g1 to get ground balance at g2g3. These two 7.4 pF caps are in series between p and g1, so net shielding cap is half that, or 3.7 pF. So measured p-g1 of 4.3 pF minus the shielding effect cap of 3.7 pF leaves 0.6 pF effective Cag1.
The screening grids are absorbing the plate field effects that normally would go thru the 3.7 pF coupling.
Accepting nominations for the Nobel, 😉😎 Now I can calculate the Cag for the 6HJ5, which isn't on it's data sheet. Same as 6DQ5, it's cousin.
g2g3-p 7.4 pF
g2g3-g1 12.7 pF
I make a socket for B9E Novar tubes....But uses the dreaded Novar base (hardly any sockets around).View attachment 1092896
https://www.diyaudio.com/community/...-usa-large-9-pin-tubes-with-1-mm-pins.378427/
Hey, alright! Lots of Novar TV Sweep tubes around yet. 17KV6A, 36MC6, 31LZ6, 12GT5, 6GF7, 17JT6A, 6LR8, 6KY8, 22JG6, 22JR6 ....
36MC6 and 31LZ6 pics below:
Oh! Oops,
We return your TV programming now to those Beam Triodes that no one wants......
Oh! Oops,
I wish I had a stack of 6HS5 beam triodes with 22, 24, 26 or 27V heaters.
Anyone wants to get rid of theirs?
Jan
Jan
For another study of shunt regulation for the picture tube, have a look at the 6BK4. Meant to be a shunt regulator for the 30KV range.
Beam Power Pentodes are also addressed an U.S. Navy technician vacuum tube training manual, attached to the linked post below. See pages 2-3 through 2-5.
https://www.diyaudio.com/community/...arning-for-newbies.38278/page-16#post-7060814
I see Vacuumtubes.net lists 6HS5 and 6HV5A for $7 and 6JD5 and 6HZ5 for $5.
Were these things on the $1 list once?
I see the 21EX6 (a normal beam pentode with cap) listed at $3. Seems like one should be able to make a beam triode by using a high Ohm resister divider from plate back to grid 2 and then down to cathode. Set it up for 200X mu or whatever. 6EX6 has a g2/g1 mu of 4.2, so a divider around 50:1. The top resister will need to be a series string to handle KV.
Yes, you are correct. My oversight.Isn't this discussion about power triodes 😗 ?
Best regards!
I discovered the 6HV5A quite by accident. There was one in a stash of random tubes I bought on Ebay. I thought at first it was one of the many capless beam power pentodes for horizontal output, but research proved differently. I'm thinking of using them in a monster class AB push pull amp with a little positive bias on the grid so that they can wake up at less than electric chair-type potentials. Since they're a triode, I might have to use a follower to drive the grids. It will be interesting to see the behavior of the tube with tens of milliamps of bias rather than hundreds. There will also be some feedback to help lower the effective plate resistance. If that doesn't work, I still have plenty of monster horizontal output tubes that can be pressed into service.
The key to 10s of mA, versus 100s of mA:
The Duty Cycle of the plate current.
Single ended (has to be Class A) is 100% duty cycle
Pulse operation is most often << 10% duty cycle
Push Pull Class AB is < 100% and > 50% duty cycle
Push Pull Class A is 100% duty cycle
True Class B push pull is 50% duty cycle
Duty Cycle is often expressed as %. If it is %, divide by 100.
(50% becomes 0.5)
Multiply the plate current by the duty cycle to get the average plate current.
All the above are approximations at best, but get you in the ball park of what plate current can be safely applied.
So try to be a little conservative, do not try and squeeze out the maximum, back off a little bit.
As to driving positive grid current, each tube has either a listed, or a non listed, maximum.
You are on your own as to what is safe and non destructive.
G1 failure, thermal run-away, and what ever else may vary.
(50% becomes 0.5)
Suffice it to say, I won't be running at hundreds of milliamps of bias current for my class AB push-pull. - maybe 600Volts, 20mA, with some positive grid bias so that the tube wakes up at that low plate voltage. I may limit myself to using the GE version, as their plates are taller than Sylvania's take on the 6HV5A.
Could try a moderate B+ with a resonant RF circuit in the plate lead of the Beam Triode. Drive the resonator externally (or possibly by RF super- imposed on the BT grids) to reach EHV, so the Beam Triode would have EHV on it's plate half the time. Could use two parallel tubes out of phase for normal 100% duty operation.
I was looking closely at the 6HZ5/6JD5 tube here and the grid has much finer wire pitch than typically seen on Sweep pentodes, almost like a frame grid. So that's explaining the 2X higher gm than a comparable Sweep at 300 mA. This would make me a little leery of pushing the grid too positive. Some +
voltage limiting seems like a good idea.
There still remains the very high output impedance of these tubes. OK I guess for Electrostats. Could fit in with a Berning type impedance converter, which could generate the EHV as well. Not much room for cost savings over a normal Sweep tube then.
Using 3x 12HL7 tubes in parallel would get you the same gm level and Watts at lowish normal B+ and normal steady current. Fabulous internal triodes too. Sensitive frame grids, but no need to take them positive. But some attention to keeping them under control (parasitic osc.) would likely be needed, and individual biasing. I bought a box full back when they were $1, but I see them listed for $3 now.
The other option I see is 38HE7. These are cheap, can do 15 Watt each (using only the B pentode in the bottle) at normal B+ and current, and also have quite nice internal triodes, better than most Sweeps. 30500 total gm at 150 mA each tube for two tubes.
SA - that sounds like a whole lot of trouble for something that can probably be had rather simply and directly. As I also said, if the beam triode gambit doesn't pan out, I have a bunch of 35LR6s waiting in the wings that would be more than happy to pump out the watts. In that case, the amp could use pentode mode with feedback for triode emulation, screen drive, or maybe even "crazy" drive.
- Tubes / Valves
- Advantage of beam triode over simple triode
