AB100 Class AB Power Amplifier
Hi Guys,
First of all thanks to NP and Prasi for the design and PCB
I am planning on putting this together, but just had some quick questions. What should the values of L1 and R37 be?
Also at the position C7 should there be a film cap and the electrolytic over it? Also any ideas for good values of the fuses F1 &F2?
Have a transformer with 36V secondaries should five ~50VDC right? Or should go with a lower rail voltage? maybe 24V secondaries?
Thanks for the help
JK,
+-50VDC will work fine, my working voltage is +-37VDC.
For the inductor I have used 1.5 mm copper wire wound about 8 times around a 13mm drill shaft to fit the holes in the pcb. For the resistor I have used 10R 3watt and I have used 5A fast blow fuses for the rails. For C7 I just used a 10uf cap. Hope this helps.
Hallo Andrew,
I used this layout by Prasi.
Prasis PCB has TO126 transistor for bias generator (easier mounting on the heatsink) and it has a film input capacitor (space for it).
Also its contain output coil +resistor + reverse protect diodes between rails/output
Of the two Gerbers posted, Mr. Pass in post 463 or by Prasi in post 812, (were there others I missed?), Prasi's is the board to have made?
