Not to step on toes, but here are my files.
Board is 2.85" x 9.725" and the Gerbers are in the format that pcbway.com
seems to be happy with.
When I upload these, I get "No outline" error...
JK,Hi Guys,
First of all thanks to NP and Prasi for the design and PCB
I am planning on putting this together, but just had some quick questions. What should the values of L1 and R37 be?
Also at the position C7 should there be a film cap and the electrolytic over it? Also any ideas for good values of the fuses F1 &F2?
Have a transformer with 36V secondaries should five ~50VDC right? Or should go with a lower rail voltage? maybe 24V secondaries?
Thanks for the help
+-50VDC will work fine, my working voltage is +-37VDC.
For the inductor I have used 1.5 mm copper wire wound about 8 times around a 13mm drill shaft to fit the holes in the pcb. For the resistor I have used 10R 3watt and I have used 5A fast blow fuses for the rails. For C7 I just used a 10uf cap. Hope this helps.
What are the differences between Prasis layout and Nelson Pass's layout?
Hello Vrystaat
greetings and many many THANKS for sharing schematic and pcb files
surely will try it.
warm regards
Andrew[/QUOTE
Just a pleasure Andrew !
There's a completely free Gerber viewer which runs in your browser, you don't need to give your email address or download anything.
http://www.pcbxprt.com
Prasis PCB has TO126 transistor for bias generator (easier mounting on the heatsink) and it has a film input capacitor (space for it).
Also its contain output coil +resistor + reverse protect diodes between rails/output
Of the two Gerbers posted, Mr. Pass in post 463 or by Prasi in post 812, (were there others I missed?), Prasi's is the board to have made?
I’ll bite. Post #832. A little more work is needed as I had some parts on hand already so there may not be a link for every part. But I believe everything is listed.
AB100 Class AB Power Amplifier
And in the future Freecrowder don’t even bother using the forum search function. Google is way easier.
Hi All,
Not sure if I posted this previously but I was PM'ed about it so here is the BOM I created for the NP pass boards for those interested.
Thanks!
For the dumb dumbs among us, any chance of filling in Mouser or manufactures part numbers where you used items from your stash?
- AB100 Class AB Power Amplifier
