A Directory of Apex Audio Amplifiers
SR200 V2
PCB V3.2 [Toshiba] by alex mm
PCB V2.2 [Sanken] by alex mm
Power of SR200 is 200W/8R, coil have 12 turns on 10mm diameter with 1,2mm wire.
  • PCB SR 200 V3.2.pdf
    PCB SR 200 V3.2.pdf
  • PCB SR 200 V3.2 ALL.pdf
  • PCB SR 200 V3.2 SILK.pdf
  • APEX SR200 V2.2 SANKEN.pdf
  • APEX SR200 PCB V2.2 SANKEN.pdf
Apex SR150
PCB by 44250
Maximum voltage +/- 55VDC
Apex SR100
PCB by alex mm and zip file PCB from JOHN BALI[/] and olafk
White cap is PCB John, red cap Olaf
No, im build only D14 (A100) and AX14 (no more about 120WRMS) - don't have trafo more that 42VAC for more power, and now i think to build SR250 (i have printed toner and i think build or not) or D200/500 and must have SMPS (little price about standard toroid the same power), i cloned pcb APEX SPS-1000 but i don't know is tested or not? Dont have scope yet. Im waiting for good offer (at little cost) something Analog Hameg or Tektronix.
Im only hobbyist
P.s.
I need amp for Beyma SM-212 (350W RMS 8 Ohm) https://www.beyma.com/products/lowmidfrequency/112SM2128
Any sugestion ? I must build amp too 350W RMS 8 Ohm ?
Hello xrk971
greetings FH9HV 50 volt rails+/- i will try it tomorrowi have all compnents
in the year 2000 i had purchased these hexfets matched them for anthony
holtons AV1000 AV800 FH9 is a very nice sounding amp many thanks to you for
building it and special thanks for kashyap for very nice pcb design
warm regards
Andrew
Can you post post link to the schematic, pcb...?
Sorry I have been lazy and not updated schematic since the sim.
The main changes in implementation vs schematic is MPSA42 VBE multiplier is exchanged for BD139 as it had convenient mounting hole.
For FH9 HV change BD139 for KSC3503 (2 places) and BD140 for KSA1381 (1 place). Make sure all electrolytics and bypass caps are rated 63v or higher. For feedback shunt cap, lower 16v rating is fine, I use a 35v one there.
550019d1463581537-100w-ultimate-fidelity-amplifier-fx8-xrk971-hexfet-vbe-schematic-v2.png
Hello xrk971
warm regards
Andrew
I noticed you don't have 100pF caps next to the drivers. There was a newer version of the PCB by Sonal Kunal that had this change. You can always solder it directly to pins of the drivers. It might make it sound smoother or help ensure stability.
559344d1468167459-directory-apex-audio-amplifiers-13644280_10209187595280978_2096441955_n.jpg
Hello xrk971
greetings thank you for pointing out the omitted 100 pf caps on my pcb
FH9 HV can a another pair of output hexfets be added to the existing
schematic for +/- 50 volt dc rails for 4 ohm speaker loads hexfets are
cheap
warm regards
Andrew
