SR200 V2
PCB V3.2 [Toshiba] by alex mm
PCB V2.2 [Sanken] by alex mm
Power of SR200 is 200W/8R, coil have 12 turns on 10mm diameter with 1,2mm wire.
Apex SR150
PCB by 44250
Maximum voltage +/- 55VDC
PCB by 44250
Apex SR100
PCB by alex mm and zip file PCB from JOHN BALI[/] and olafk
White cap is PCB John, red cap Olaf
HX11 (AX11 H Class 300W) > http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-222.html#post3504633
Tested> http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-233.html#post3525919
wiljj78 version > http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-229.html#post3516547
And tested > http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-309.html#post3826043
Thanks for all the links Zynix. Have you built any SR amps ? What's the main difference between SR amps vs AX FX or A amps?
No, im build only D14 (A100) and AX14 (no more about 120WRMS) - don't have trafo more that 42VAC for more power, and now i think to build SR250 (i have printed toner and i think build or not) or D200/500 and must have SMPS (little price about standard toroid the same power), i cloned pcb APEX SPS-1000 but i don't know is tested or not? Dont have scope yet. Im waiting for good offer (at little cost) something Analog Hameg or Tektronix.
Im only hobbyist
P.s.
I need amp for Beyma SM-212 (350W RMS 8 Ohm) https://www.beyma.com/products/lowmidfrequency/112SM2128
Any sugestion ? I must build amp too 350W RMS 8 Ohm ?
Im only hobbyist
P.s.
Great to hear that you like the FH9 Andrewlebon. Was it pretty easy to adjust initial bias current? Don't forget that the FH9 HV option exists if you want 50v power supplies.
Hello xrk971
greetings FH9HV 50 volt rails+/- i will try it tomorrowi have all compnents
in the year 2000 i had purchased these hexfets matched them for anthony
holtons AV1000 AV800 FH9 is a very nice sounding amp many thanks to you for
building it and special thanks for kashyap for very nice pcb design
warm regards
Andrew
warm regards
Andrew
Can you post post link to the schematic, pcb...?Don't forget that the FH9 HV option exists if you want 50v power supplies.
Sorry I have been lazy and not updated schematic since the sim.
The main changes in implementation vs schematic is MPSA42 VBE multiplier is exchanged for BD139 as it had convenient mounting hole.
For FH9 HV change BD139 for KSC3503 (2 places) and BD140 for KSA1381 (1 place). Make sure all electrolytics and bypass caps are rated 63v or higher. For feedback shunt cap, lower 16v rating is fine, I use a 35v one there.
Hello
greetings anyone have this apexaudio pcb design😉
warm regards
Andrew
On Apex's Facebook page he says that is AX11. However, looks like several parts have been exchanged. That's a tiny Vbe multiplier that's hard to mount.
Hello
warm regards
Andrew
Andrew pcb layout is similar to Willy's and Juan's layout.
You can request sprint files from them and edit layout to to make it same size as pcb on picture.
Hello
warm regards
Andrew
I sent you a Facebook link to the author of this layout.
Hello xrk971
warm regards
Andrew
I noticed you don't have 100pF caps next to the drivers. There was a newer version of the PCB by Sonal Kunal that had this change. You can always solder it directly to pins of the drivers. It might make it sound smoother or help ensure stability.
Hello xrk971
greetings thank you for pointing out the omitted 100 pf caps on my pcb
FH9 HV can a another pair of output hexfets be added to the existing
schematic for +/- 50 volt dc rails for 4 ohm speaker loads hexfets are
cheap
warm regards
Andrew
cheap
warm regards
Andrew
- A Directory of Apex Audio Amplifiers
