A 3 way design study
For bass (<100Hz and down) nothing matters more than displacement. So get the driver with the most displacement you can afford.
There's a few guys here who are small speaker specialists. What are your thoughts? @wolf_teeth
Peerless SLS (if you can find them)
Anarchy 554 ?
E150HE ?
If you go ported, consider down-firing or rear firing ports.
But seriously, if this is for desktop use (1-2 ft) listening, you really don't need 95dB per speaker...nor do you need the bottom octave (20-40Hz) with most music.
I'd consider the L16RN-SL...
  • Thank You
Reactions: vineethkumar01
The SB23MFCLs are not available in my country right now 🙁
Peerless, Dayton & Anarchy drivers also, same situation..
How does this wavecor driver look? (Has the same kind of xmax as the SB23MFCL and is 20mm smaller in diameter)
https://www.wavecor.com/html/sw215wa01_02.html
I can get these drivers at a reasonable price (2/3rd) that of the SB driver. The intended crossover to the Sica coax is somewhere above 200Hz.
I did a simulation including the effect of inductance & some linkwitz transform in a 10L enclosure and this is how it looks. Is it any good for this application?
Reactions: IamJF
Thanks @wolf_teeth.
I am slowly opening up to the possibility of an 8inch and make a box like below (from Mabat's original sketches):
Unfortunately, these days, the only Dayton drivers I have access to are RS180, RS150 and RSS265HO. The RSS265HO being unjustifiably costly here.
Most drivers are either out of stock here or not available at all. And because of the import duties, driver cost doubles if I buy it from abroad.
Some of the wavecor drivers & selected SB and Hivi drivers are the ones that are available here.
If the wavecor SW215 works, I can easily get them at a reasonable cost...
Reactions: IamJF
Thank you @IamJF for the suggestions.. 🙂
I am iterating on this box design to see how much it can be changed so that it may be a little better aesthetically.. 😀
Will post those here if I make any progress.. 🙂
Regarding kids, I don't have any at the moment.. 😀 I myself am a 35-year-old kid.. 🤓😛😀
Reactions: IamJF
@vineethkumar01 what material are you planning on building these with? Take that into consideration, if it's wood then your cost goes up to make those curvatures. Baffle isn't the problem, the top and the side curvatures will escalate costs. something to think about, if on a budget.
I think I like this one the best so far... 😀
  • Thank You
