hybrid class d amp in h mode voltage , have fun all link >>> http://www.diyaudio.com/forums/class-d/226812-my-class-d-amp-69.html#post4968835
which amplifier is suitable for 1000w RMS 8ohms subwoofer. 1) Apex ba1000(5200/1943 outputs)
2) Apex h900
3) Apex b500 ( bridge mode)...?????
2) Apex h900
2) Apex h900
B500 in bridge mode or D2000
Apex says D2000 isn't for diy.
I can't understand why?😕
Do I need bridging adapter ??or Apex b500 has its built in TL072 bridging adapter ??if so ,then which is inverted audio input point ??point A or point B??and which will be grounded??
H900P
can h900 works with 2 ohms load if I reduce rail voltage ??my plan is to build 1800watt@4 ohms ..if I connect two h900 in bridge mode and rail voltage reduced to 80 40 0 40 80 v dc .than is it ok???
Maximum Output voltage = sqrt (power * load *2)
Maximum Output current = sqrt (power / load *2), into a resistive dummy load !!
Allow at least 150% for a mildly reactive speaker load and upto 300% for a severely reactive speaker load.
Then add on for losses through the output stage.
Then add on for PSU sag when delivering that current.
Then look at what is required to drive a reactive load.
H900P
Sir Miles,
Can you point me to the schematic of this top lay artwork?
Thank you!
Albert
Happy holliday to all...
This forum is verry helpfull. Specially thanks to mr mille...
Your dsign is unic n naturally but expert.... 😉
good job sir...
Nice..
[image][/image]
hi mr.rizqi
can you tell me, how do you drawing part symbol on top side pcb
this my 2nd build apex h900 amp,,,almost done,,🙂
hi all , why is tl072 version amp not stable . and can someone please share a stable version not using ir2117
diyaudio.com 900W H-class PA Amp with Limiter pg 9 APEX STEP DRIVER.jpg252.7 KB · Views: 1,040
forum.vegalab.ru V.2013 storey PRO-amplifier in the class H pg 11 3 ?????.GIF53.2 KB · Views: 1,001
diyaudio.com 900W H-class PA Amp with Limiter pg 253 DSC_0541.jpg948.5 KB · Views: 988
diyaudio.com 900W H-class PA Amp with Limiter pg 254 197609d1290487375-900w-h-class-pa-amp-limit.gif58.2 KB · Views: 927
- 900W H-class PA Amp with Limiter
