900W H-class PA Amp with Limiter
This amp class H from Indonesia...$750.
Maximum Output voltage = sqrt (power * load *2)
Maximum Output current = sqrt (power / load *2), into a resistive dummy load !!
Allow at least 150% for a mildly reactive speaker load and upto 300% for a severely reactive speaker load.
Then add on for losses through the output stage.
Then add on for PSU sag when delivering that current.
Then look at what is required to drive a reactive load.
hi all , why is tl072 version amp not stable . and can someone please share a stable version not using ir2117
  • forum.vegalab.ru  V.2013 storey PRO-amplifier in the class H pg 11 3 ?????.GIF
  • diyaudio.com 900W H-class PA Amp with Limiter pg 254 197609d1290487375-900w-h-class-pa-amp-limit.gif
