8 Excel W12CY001 looking for a DIY project to fit in
Sorry for the delay. Here is your impedance data. You can now simulate an accurate crossover 🙂
Note the frequency response and impedance for the W12CY001 is for dual parallel woofers so they can be treated as a single driver in simulation.
A quick crack at it myself. That bump around 1KHz is mostly unavoidable cabinet diffraction (but is pretty mild IMO).
Inverted null
Xover network.
Below is another variation with a better inverse null, but also a bit more of that mid-bump.
Inverse Null.
Xover network.
In all shunted series LCR networks (one in the bass/mid branch, two in the tweeters') the resistors represent the total resistance.
So deduct the coil resistance (caps are presumed zero in practice) and calculate the "real" R value.
Perhaps stating the obvious, but also each individual coil in other positions has its' resistance shown by the R element, which is not "real".
Reactions: Tenson
I was experimenting with another mic I have, also uncalibrated, but seems to be flatter than the previous one in high frequencies range. 1/12 smoothing. Tweeter resistor set at 1R5, to match closely the amounts of highs on DXT-MON-182. Some stuffing also added, it used to be very light before - just carpet tiles.
I recommend using a 5dB scale for this kind of thing. 10dB is too course because our ears are far more sensitive.
Your result looks pretty smooth. The only thing that bothers me is the 3 to 4dB broad hump between 4KHz to 10KHz. That is due to the waveguide.
I would recommend sticking the data I supplied in to your simulation and see how it looks, then you can make a few tweaks. Remember to delete one of the woofer because my data is for the pair already.
