Yes.Is there please a trimpot to finely adjust the output, please ?
Yes.I have a 7 VAC/2A torroid output and need a lowdrop reg for a 6.3 VDC filament tube. Has my torroid traffo output voltage enough to use your reg?
I use LM338 for 2 pcs ECC99/800mA And for cooling I need 8x8cm with a thickness of 1cm.How can a 4cm cooler cool 2.5A???
because dissipation is only 3W at that current.
With 6.3VAC input, you are looking at 7V rectified, and the module works with very low input-output voltage.
No, but the maximum current is lower than 2.5A, more like 1A at 9VAC in, and the cooler will get very hot.
Hey. I just want to advise that I bought 4 of these and they are stellar. THANKS. 🙂
