2stageEF high performance class AB power amp / 200W8R / 400W4R
how to run 2 stageEF_class_AB asc?
You can download the program, download the archive with libraries that are circled with a red line in the figure and click on the RUN icon. But this is probably an old version of the amplifier file. Ask the author for a new one, because when overloaded, Q6 will emit magical smoke if its current and voltage are not limited.
Reactions: 1 user
Joined 2011
Just tried the zip content from post 1149 with the newest LTSpice version 17.1.5 fresh installed in a new Linux-Wine directory (= behaves like a fresh installed windows 7)
My directory content:
-rw-r--r-- 1 toni users 1493 11. Aug 2014 2SC5200_2SA1943.lib
-rw-r--r-- 1 toni users 49903 3. Aug 2014 2stageEF_class_AB_power_amplifier_v3.asc
-rw-r--r-- 1 toni users 2959 11. Aug 2014 2stageEF_class_AB_power_amplifier_v3_soa_drv.plt
-rw-r--r-- 1 toni users 19947 1. Aug 2016 Cordell-Models.txt
-rw-r--r-- 1 toni users 838 11. Jän 2014 KSC3503_KSA1381.lib
-rw-r--r-- 1 toni users 9960 26. Mai 2014 mylibs.lib
You need only the File "Cordell-Models.txt" which can be downloaded here.
printnik: you are right. This is an old version and Q6 would burn on overload. See attached sim result picture of the latest asc
BR, Toni
Reactions: 1 user
Joined 2011
Had some time to work on the SA2021 new class H version. Hmm - I got the pcb's in 04/2021 - more as 2 years the project has had to wait for continuation. ( o_O )
Currently waiting for some SK76 heatsinks which are 37mm high...
Heatspreaders are machined, LTP BJT, VAS BJT, IXYS MOSFETs and TTC5200/TTA1943 are already matched...
Two new 800VA toroids (2x16V, 2x55V) are on stock...
Have fun, Toni
Reactions: 4 users
Joined 2011
... ready for testing.
Used Kerafol U90 for transistor mount (6W/mK).
First results expected this weekend. Hopefully no holy smoke...
Have fun, Toni
Reactions: 1 users
Joined 2011
Both channels are working out of the box! :cool:
supply: 2 x 20V and 2 x 31V
Quick and dirty setup: bias set to oliver voltage (~42mV across emitter resistors) and done first measurements:
0.003 % THD+N at 1kHz ~ 12V RMS @ 8R, bw 80kHz
0.006 % THD+N at 20kHz ~ 12V RMS @ 8R, bw 80kHz
This is measured at the critical supply crossover region where the "high voltage" supply steps in.
SA2021 NewClassH is working as expected! Again this smile: :cool:
BR, Toni
Reactions: 1 users
