Inputs and outputs on the same side or not ?
Many PCB design put them on opposite side, as to mimick the schematic or fear of coupling.
PCB designer should think about the outside cabling to use the PCB.
I think the better way is inputs and outputs at the same side. That gives an overall U routing on the PCB.
Sometimes the cable routing can be very counterintuitive at first examination. I mounted the left and right (unbalanced) input connectors next to each other and then ran the wires via the shortest route to each amplifier module located on the heatsinks on each side of the amplifier chassis. I had hum at about -90 dBV.
On the second approach, I ran the one cable next to the other to the first amp module and then along the top of the first module, to the front of the amp, along the front panel and over the second module to the inputs. Hum -110dBV.
In the first attempt, I had created a big cross channel ground loop that was picking up the transformer mag field. In the second attempt, the loop area was a fraction of the first and the result was ~20 dBV lower noise.
Syn08/Marcel,
I took a look at the Cherry paper. Clear that by laying the supply tracks on top of each other along with the speaker output will reduce the loop areas and mutual coupling. But, in Fig3 of his paper, he shows the speaker output coming out next to the amplifier input.
This seems to defy all the advice dished out to amplifier designers.
I normally group the 0V, supply pins, and speaker output together where they enter the board to keep the loop areas as small as possible.
I get Cherries figure of 8 idea, but not the input next to the speaker output.
Any comments from your side?
I don't think Cherry's approach is necessary a bad thing, in particular for medium power amplifiers. I don't follow the same approach, though, and always separate the signal ground from the "dirty" ground right at the input (10 ohm resistor). I also don't twist together the power supply wiring with the output wiring, I keep the output/ground wiring twisted separately.
just a typical temper tantrum, or kicking the chess table after failure to win.
But he didn't. That's a-typical.
Jan
Not a tantrum. I was being satirical. I got tired of the unending stream of unimaginably bad reading comprehension and just plain lack of reading. The vast majority of my posts have been comprised of me repeating myself. No need for me to put in the effort to continue to do so because the usefulness of the thread has reached far into the diminishing returns. Again, thanks to those that decided to be constructive and help me to this point.
There is a theoretical method of distortion reduction that does not require absolute linearity of an EC amp. Un-distorted output must look exactly like the input. That much is obvious. It follows that if the input and output could be continuously compared for phase, and that difference held at a single immutable value, then the output would be a replica of the input at any desired amplification. So the EC is a phase comparator/correcter.
I encountered one gentleman who claimed to have achieved such a feat. He demonstrated a 100W amp based on the concept. He was also very coy about disclosing additional details.
One point to be aware of, is that US patent law changed a few years ago. It is no longer 'first to invent'. Now it is now 'first to patent'. So you may have invented something before others, but if someone else gets to the patent office first, they get invention ownership.
Exactly, immutable, replica, any? These are ideal concepts, not reality.
This actually makes no sense at all. For a complex waveform phase has no meaning.
I think he means to say polarity (I hope), but this would have to be a circuit with hysteresis to prevent constant chatter, and would have an inherent error.
The quoted numbers, depending on which one you're talking about, are impossible at liquid helium temperatures (4 K)
For the umpteenth time: this thread is only about distortion, not SINAD. Nonetheless, -290 dB is exceedingly unlikely at any temperature due to passive component nonlinearity, Edward M. Cherry's magnetic coupling issue et cetera.
Phase was a bad choice. I mean time aligned, with or without an offset. Distortion alters signal shape. Therefore, at any given instant the time alignment can change. Monitoring positions of input and output in time, and ensuring that is a constant should mean no distortion. Polarities have to match. Quantum entanglement maybe...
I can dream up lots of distortions that do not change the time alignment. In fact, a fundamental with 3rd harmonic remains perfectly aligned.
Does anyone think about this before dropping this BS in this forum??
Jan
Jan
You’re right, and I do have some sympathy for hellokitty123 because people have jumped all over him without fully reading.
Those are perhaps the smartest ones. Then again, we all need some entertainment once in a while ;-)
Jan
Jan
- Analog Line Level
- -290 dB Distortion?
