• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
21st Century Maida Regulator
I couldn't find a 'maida LT3091' as an implementation for a negative rail - anyone tried/has one?
I'm using a 'standard' Maida for a B- (-300VDC) supply, just connected the positive output to ground and used ground as the negative supply. It works perfectly.
I also have some bipolar maida PCBs in my spares stash, purchased from a chap on Swap Meet - I can spare one or two if of interest?
So that's the same as Jan's with two isolated secondaries and two fb rect bridges. I was under the impression that running a -320 to 320 causes issues with the transformers loading etc.
Could I use the Maida for the B+ of a pair of Korg Nutubes? Each nutube needs 75V and will draw 64uA, for a total of 128uA (or 0.128mA).
I've attached the calculator output. For R3 and R9, I was planning on using 1W Vishay CMF60 resistors. Are those alright?
Don't forget to account for the load current in that case. I'd probably make R3 = 100 Ω. That'll set the current limit to about 35 mA, which would be plenty.
1 W resistors would be plenty.
A use case where hardly any current would be drawn from the regulator did not occur to me when I wrote the spreadsheet, so I didn't account for that. You'll always have at least 2 mA flowing through R3 due to the feedback resistors, so it really should be no higher than 1.6 kΩ.
Tom
Tom
Hi Tom, what is the psrr of the reg, I can't find the graph..?
I doubt it. There is a schematic in Post #1, though.
I've made a few tweaks since then, but it should provide a starting point for you if you'd like to DIY the circuit.
Tom
It's ok, thanks, jackinnj sent simulation file, I need it only for comparation, I'm experimenting with another "maida type" topology... Btw I'm used to Micro Cap, LT spice is still not user friendly after all these years. 😡
QQ- what ripple input would expect for a tube amp? I’m targetting as close to sub 0.1uV ripple (320V 160-200mA)
Do users normally use one or more chokes to give a starting point for the regulator to work from at that level of output? (A 3H choke with 375uF caps give ~ -53dB for example)
