here you go.
prasi
Hello Prasi,
https://www.diyaudio.com/forums/solid-state/164093-100w-ultimate-fidelity-amplifier-post4686633.htmlFor some reason JLCPCB can't seem to figure out the gerber files from post #7150. (FX8 Bimo Mod.) It complains about non-standard gerbers, etc.
Could you please replot and post the gerber files so that we can try again with JLCPCB?
Hello Prasi,
try with these gerbers, this should work.
Ok. Thank you.
I uploaded those to JLCPCB (see attached) and in their gerber viewer I wonder if their software is having a problem with the drill holes? In the gerber viewer it looks like the drill holes are missing?
They changed gerber view. Not as good as ex one. I have checked gerber in ViewMate Pro and all is OK.
You can check also with gerber viewer placed here China PCB Manufacturer & Assembly - NextPCB
Hi group members, all good, first I would like to thank Mile Slavkovic for the excellent projects and for all the members who design the amplifier layouts. I have some doubts and if anyone answers I will be grateful, I set up the apex ax11 amplifier with 2sc5200 and 2sa1943 output transistors, with bd139 as Bias, what are the acceptable values of the Bias adjustment?
Is it normal for the mje340 and 350 to get so hot?
Can i replace with tip 41 and tip42?
And which resistor is responsible for increasing the gain?
I set up the pcb for this post
100W Ultimate Fidelity Amplifier
Hi fabiomaster,
For increasing gain , refer this post.
For bias, referring the same schematic as above post, delta V measurement should be done from emitter of Q10 to emitter of Q11. Normally class AB amp it should be 25mV to 30mV.. So bias current is ~ 50 to 60mA or there about.
I do not know if MJE 340/350 getting too hot to touch might indicate problem in AX 11. .
if bias and offset are correct and you are getting sound output with test speaker, try a small heatsink for them (mje340/350). if temperature is ok, then you are good to go.
- 100W Ultimate Fidelity Amplifier
