100W Ultimate Fidelity Amplifier
Ok. Thank you.
I uploaded those to JLCPCB (see attached) and in their gerber viewer I wonder if their software is having a problem with the drill holes? In the gerber viewer it looks like the drill holes are missing?
Hi group members, all good, first I would like to thank Mile Slavkovic for the excellent projects and for all the members who design the amplifier layouts. I have some doubts and if anyone answers I will be grateful, I set up the apex ax11 amplifier with 2sc5200 and 2sa1943 output transistors, with bd139 as Bias, what are the acceptable values ​​of the Bias adjustment?
Is it normal for the mje340 and 350 to get so hot?
Can i replace with tip 41 and tip42?
And which resistor is responsible for increasing the gain?
I set up the pcb for this post
Hi fabiomaster,
For increasing gain , refer this post.
For bias, referring the same schematic as above post, delta V measurement should be done from emitter of Q10 to emitter of Q11. Normally class AB amp it should be 25mV to 30mV.. So bias current is ~ 50 to 60mA or there about.
I do not know if MJE 340/350 getting too hot to touch might indicate problem in AX 11. .
if bias and offset are correct and you are getting sound output with test speaker, try a small heatsink for them (mje340/350). if temperature is ok, then you are good to go.
