100W Ultimate Fidelity Amplifier
Yes, there is psu on each board. Here, for example, is the AX-20 board
FH9HVX
Hello
greetings just finished FH9HVX on a single sided pcb .😉😉😉
Thanks to xrk971 for this lovely amplifier.
warm regards
Andrew
Learn how to use PCB/Schematic drawing software is easy. But learn how to make good PCB layout is difficult.
As long as you keep connections between components short and thick, you will do alright. And do not use ground planes in amplifiers.
Using dual side pcbs is fine, because you will be able to shorten your connections between components.
These basic rules are a good way to start designing.
Add other tips you may find useful.
Hi Nick,
here are the files🙂. be very careful in soldering as components are in close proximity due to compactness of pcb.😉
Another thing, if you want quickly the pcbs for this amplifier but different pcb design/size, xrk 971 has already his version of pcb in his store , have a look at GB section or his store here FH9HVX Amp PCB | Etsy
regards
prasi
What is the recommended transformer size for 4 or 8 ohm?
