Mr. Mile,
What's the changes if I will use AX14 with 80-0-80 VDC rails using 3 pairs A1216/C2922 SANKEN transistor?
Thanks,
No changes, use 4r7 base resistor and 0,33r for emiter for each output transistor.
This is my AX14 with TEF OPS 7 pairs of output
I assembled this last January 2012 running on +/- 90 VDC
Thank you...
Nice one remle, can you share your driver board?
Sorry sir willy this s a 3 year old project and i lost all my files because my hard disk failed a year ago
Its Ok sis... thanks anyway i'll pm you.
Thank you...
There is AX20 with 3 pair... use this schematic.
Well noted, Thanks..
I am not so fast like Terry, but.. 🙂 I would like to also try P30 like universal preamp for my power amps.. I hope, that will work for all amp, which i already build...
Some more update on 8 Channel Amp building. Still waiting for few caps to arrive.
Nice work,
it's time to try some other Apex 😀
Nice choise A14 is very good CFA amp with diamond OS, P30 CFA preamp will work with any amp.
maybe this would help?
(in first Zip i´d say it was Ardrew Lebon´s work,all the other files are from OlafK)
Thanks for posting. Much less confusing doing through-hole construction, those class D amps can get fiddly for me.
I love AX-14...
can mjl21193-94 be used in ax-14 without stability problems?
Yes, and many other pairs.
- 100W Ultimate Fidelity Amplifier
