Mr. Mile,
What's the changes if I will use AX14 with 80-0-80 VDC rails using 3 pairs A1216/C2922 SANKEN transistor?
Thanks,
No changes, use 4r7 base resistor and 0,33r for emiter for each output transistor.
Thank you...
This is my AX14 with TEF OPS 7 pairs of output
I assembled this last January 2012 running on +/- 90 VDC
Nice one remle, can you share your driver board?
Sorry sir willy this s a 3 year old project and i lost all my files because my hard disk failed a year ago
Its Ok sis... thanks anyway i'll pm you.
Thank you...
There is AX20 with 3 pair... use this schematic.
Well noted, Thanks..
Some more update on 8 Channel Amp building. Still waiting for few caps to arrive.
Nice work,
it's time to try some other Apex
Nice choise A14 is very good CFA amp with diamond OS, P30 CFA preamp will work with any amp.
maybe this would help?
(in first Zip i´d say it was Ardrew Lebon´s work,all the other files are from OlafK)
I love AX-14...
can mjl21193-94 be used in ax-14 without stability problems?
Yes, and many other pairs.
- 100W Ultimate Fidelity Amplifier
