100W Ultimate Fidelity Amplifier
Nice work, is it tested, can you post schematic? 🙂
i have checked it visualy for a few times and haven't found any mistakes, if anyone finds some please let me know. the input-voltage stage is done by Dude's layout wich was based on wiljj78's pcb,that part was tested in to3 version only i aded one MPSA transistor as suggested. i believe that Dude will be the first to test it and i'm sure that he will share video,pictures,impresions and some measurments.
i am not used to draw schematics,i only draw a few schematics ever but today i will try to in Tina-TI program.
at my mobile i couldn´t but just now at my PC i see a smiley at your post APEX,and let me tell you- No,it will not be made with seven pairs of output and to be put at +/-100 // +/-200Vdc power supply - it stays like this. do some reverse ingeneering to get schematics... 😉 🙂
just kidding 😀
Sprint Layout 6
I found the: sprint-layout_6_setup.exe.
but still I can not open the file you uploaded.😕
maybe your progam still demo vertion,... in full vertions, could be edited with best layout,... thanks... 😉
This is my sample in full vertions
Regards :shhh:
H-klasa in pdf (a bit changed...)
maybe this will help:
Hello
I have small question, I had some small problem with brumming noise from ax14 amp when input was not connected (prapobly due my board), I have made small change with r2 22k resistor and problem is gone. Now question is if I can leave r2 resistor connected between input and gnd ??
