1000W Simple PA Amplifier
hi apex sir, is this step works with ba1200?
I used to get them a few years back on a local electronics store , they haven't blew up or anything , maybe just that some stores still had surplus devices ?
Now I can;t find them anymore , definitely not in the RS catalog, fairchild produces analogues although with a 20 volt higher max rating and 2 amp more current.
Disabled Account
Joined 2014
re apex BA2000
hi I found that Proline 3000 also same as ba200. but i dont know how the protection circuit works without any power supply.
pls see the attached pdf schematic. protection circuit stars only from sp out and then goes to GND.
Can any expert explain this or is there any mistake on the schematic ?
also can someone design the input board pcb layout ?
  • proline-3600-amplifier-schematic.pdf
Disabled Account
Joined 2014
apex ba2000
Dear apex audio sir,
I build the amp. Switch on through 100w bulb. Dc offset is fluctuating. But beliw 20mv with bulb series.
Dont know why fluctuating it. I never tried direct 230v supply as even with bulb series tripple emitter ,means drivers get hot. But bulb dims very well.
Anyhow I gave audio signal . I heard big noise. Like raining sound. Biad preset also not answering. Got 440mv on base and emitter of outputs. Even rote 330 preset it remains same.
Is that also due to ossilation ? Any idea what to do sir?
