Q17 Sigma22 Regulated Ultrastable Ultralow Noise Linear Power Supply +-50/60Vcc
I am not seeing an "*.asc" file on your github repository. (You can post LTSpice *.asc files to DIYAUDIO)
Would suggest that you hang a current source of AC=1, DC=25m on the output. If you run an AC Analysis and plot Vout/Iout you will derive output impedance. Good to know.
From the output impedance you can derive stability.
No, this design is not stable for a very simple reason. Capacitor C16 needs series resistance, even an Ohm. If you use a film capacitor here the phase margin is reduced to 31 degrees at 280 kHz. (Using the Erikson Maksimovich approximation where:
Q = f * tg * pi and
PM% =~ 50.363 * Q^(-0.907)
You could also just eliminate the capacitor as it serves no useful purpose.
It's a flaw you see all the time from DIYr's who think more film caps are better. The remedy is quite simple.
An old fashioned AM transistor radio is helpful in testing power supplies for oscillation.
You can make an LM317 oscillate if you use only a film cap on the output node.
If you have to bypass something do it as close as possible to the sensitive stage and use a ground plane.
Reactions: jan.didden
Hi folks,
If you find anything that could be improved, give me a summary at the end. I'll fix it on Github when I have a little time.
There's also something I noticed: one of the polarities, the positive one, if I remember correctly, starts up slower than the other. About half a second. It would be good to try to correct that.
About the 1uF red caps at output. I know, I exaggerated a bit for aesthetic reasons, but you don't have to put them in. The 0.1uF at the input are also useless. It's a relic from the prototype that I forgot to remove.
Otherwise, in practice, the power supply is reliable and durable.
Stef.
