Linesource measurements and xoverbuilding
That's looking very good! Is it on the same sight line as your ears while seated?
If not, is tilting the speaker about 5 degrees an option, or will it fall over?
Is the tweeter above ear level. I could look back to your sketch, but asking is quicker.
  • Thank You
Reactions: jawen
300 hz
Last was ca 7-8 cm above my ear, and the one before that (gated to ca 350 hz) was earlevel.
Left speaker only!
Are you using REW? Has smoothing been applied? If so, how much? I usually use 1/6th during x-over work.
That's really impressive for the speaker standing on the floor, and not raised. Can you move the gating down to 200hz without a bunch of wrinkles showing up in the response?
  • Thank You
Reactions: jawen
Yes using REW
Speaker stand on the 62 cm high 15 inch ported Dayton rss390ho in 100 liter, pointing on mic/me in the sofa 3,1 m away, but mic at 2 m.
Will try gating to 200 hz and post it here soon 👍
I know you probably don't want to make a lot of work trying x-overs, so I'll assume that there's no need for more Sims. But Sims are fun! Can you post a 300hz gated frd of mid, and tweeter with 1/6th smoothing?
What smoothing are you showing now?
I always use Var smoothing in REW (its like 1/6)
Yes, sims are fun and interesting!
Will measure mids and twee gated at 300 hz and come back to you with frd files.
Thank you temp25, for pushing me forward.
REW has an option to show below the 300hz gating as a dashed line. It is said not to be as accurate below the gate, but sometimes visually, the dashed line makes it easier for me to tell what I'm doing. You might like the feature. Gating generally shows a low end roll-off. I just ignore that, and think of it as flat below the gate, even if it's not.
Nothing magical about 300hz. If you can get to 250hz, that's a hair better than 300hz. The end result will be close with either gating. It's tricky with 3-ways, or 2.5-ways to get good low frequency accuracy. If you were making a 2-way 300hz gating would be suitable, no question. I spend a lot of time listening, and making changes based on both what I hear, and measure.
Reactions: jawen
You can still gate the original measurements from a week ago. You don't have to retake them, if they are still in REW.
Dont have many of them, REW becomming a probleme for me.
But here is a new frd file for the tweeter.
But measurements on the 4 midrange seems to be diffucult, dont know where to put the mic?
1 m as the tweeter isent good, and not same SPL if i move the mic away?
Check this out. I drew the schematic in an awkward way, but it is essentially correct, I think. Only 10 parts in the x-over.
  • Thank You
Reactions: jawen
You apply a gate on an already made measurement so no need to listen to the sweep to get a gated version. We really don't do gated measurements, we do gated presentations. It's a misnomer.
Select a measurement in left pane. Klick on the "IR Window" button and enter e.g. 5 into the field "Right width (ms)" - hit Enter.
See the measurement changed to being devoid of energy for later incoming additions (reflections) than 5ms.
Reactions: shadowplay62
Yes, thats what i did when temp25 ask me for 300 hz and 200 hz gated measurement, but then REW crasched so these 8-10 measurements are gone (except the pic i took from print screen)
Nowadays REW crasch even before i maybe have time to take the first measurement, & have time for a maximum of 5 measurements before I have to restart REW.
Before i sometimes have the problem with that REW shout down it self, when i push the "start" button in measurements, often after i did some new soldering on xover and REW was just "stand by"
But the problem with REW now is that the microphone output suddenly disappears & a warning box from REW pops up.
But then the REW program doesn't respond no matter what I do, so I have to ctrl+alt+delete & via the task manager to abort and end REW. (process)
Have a 3 meter extender-cable at the microfone, maby some problem with that, even if it have worked for 2-3 years?
OR that REW has got some bugs in latest version?
And saveing after every measurement become not "organized" anyway.
Reactions: TNT
