Linesource measurements and xoverbuilding
The Data in post 33 is interesting but it doesn't show what happens if we cut the bass drivers out of the overall picture
Do you mean to also cut the 4 midranges from playing 250 hz and downwards?
how do you feel about the current sound. As suggested maybe it is worth doing an average over the listening area which is the TV sofa. Maybe the area where you were thinking you needed a notch filter at 1.2KHz how does that look in separate measurement's across the width of the sofa. Is it hot directly on axis, but isn't there on the ends of the sofa ?
It sounds real good, and i now have a little toe-out on the nearest speaker (right one)
So spl perceived equally ( i sitt to the right in my sofa, near computer)
I have 2 different xovers on left and right speaker.
Left speaker have a notch at ca 1200 hz, and some other small changes
Do you have a single woofer zma? Edit.. I guess porting has changed it some. Porting may or may not be optimum, but that's one of many design choices. So, don't worry about posting a new zma. It is what it is.
i have solder the woofers in serie inside with a short cable between possetive and then negative on the 2:e woffer.
So hard to do that, BUT not impossible if i unmont a woofer and solder it 8 ohm (with the woofer beside it "dead")
That probably changes the ideal filter, but here's the one I was working on. Try this filter in your sim. I can also show you one where the woofers go up higher. If you cross to the sub at 200hz there's not much being played by the outer woofers using this filter. It really becomes subjective.
Reactions: jawen
I will simulate you values 👍
Just take 2 measurement from my sofa on left speaker, mic at ca 2 meter 1/3 up on speakers hight.
So mic is around the lowest midrange above the 2 lower woffers.
Tweeter in phase and out of phase
