Budget Classic 3-way Discussion Thread
@shadowplay62 - wow, those are really good discounts! Does Soundimports have similar discounts with an account or is THLP just less expensive (with an account)?
THPL is a big seller, as they are an important (OEM- reseller/distributor/importer/exporter for brands arround the world. And so they can buy cheap (1000x a driver is much cheaper per unit than 10x). I heared from insiders that their official prices need to be what is the MRSP, but to "members" they can give discounts. So they give them if you make an account and become a "member". DIY is only a fraction of their bussiness, but is the way that most learn about them. Sound import is their main rival, but sound import does not work on the scale of THPL. Other shops mainly buy b2b from one of those two, if they don't buy from the brand direct (for EU brands).
I do not know as I do not have an account at Soundimports, generally the prices are similar but that may depend on a particular brand and/or availability, e.g., TLHP does not sell Dayton speakers and you do not get any discounts on Audax drivers. Sometimes Dibirama is cheaper than other shops.
Consider that the stac tw costs 40€ when you are not logged in.
That is an old one, not on the SB site, and ‘to be discontinued from Q4 2020’ at TLHP 😉. I wouldn’t bother considering it. The chamberless version I have though is even cheaper and very good for the money. I crossed it with a WG at about 1,7kHz with no problem.
They stock them as OEM since 5 years so (Probably for companies that use them). Since only the faceplate is plastic instead alu ,It's just good to know that if we go for the STAC, peaple can take this one to win 10eu if they don't care about the alu face plate ...
Has the option to use a waveguide for the tweeter already been discussed? For me personally, optimising the radiation with a WG would be preferred. But I would understand it would add to the complexity for someone to make it, seems it would ask more woodwork for routing and 3D-printing (or cnc if one wants to splash).
Maybe use the pre-designed 5" wg for the SB26ADC from @augerpro?
@Arnandsway
Yes. We will have a "classic" design reflecting the heritage of vintage "Monkey Coffin" designs of the ~1970s era. Non-waveguided tweeter, no edge treatments.
We will also (probably) have a modified version with a waveguide tweeter and chamfered or rounded edges. The idea originated with the ease of using one of the stock SB26 tweeters and putting the same tweeter in an AugerPro waveguide. If we don't select one of the SB26 tweeters we can still do something along these lines.
Not to go off rails, but a 'best in show' monkey coffin type design - though looks like a 15 and wave guided tweet.
Reactions: 6thplanet
That SB26STWGC is quiet good it seems. I never used it but it looks low distortion to about 1000Hz, so fit to cross arround 1500Hz. The top end is not as good as some others, but it's issues are minor if i may trust some measurments made here. Price is arround 90€ in Europe, a bit more expensive than others mentioned, but if it fits the bill it may be a good choice to have a small waveguide without fuss to make or design one as it's the frontplate of the tweeter.
waxx,
Thanks for chiming in. Since it is a small waveguide, possibly it will not be a big departure from the classic speaker aesthetic that the participants of this thread are trying to remain faithful to.
3D printing a WG has its own set of challenges, and the SB26STWGC unit should be simpler/easier to mount.
Yes, the SB26STWGC is a good tweeter. The waveguide will probably help control directivity and lessen the negative impact of the sharp edged baffle, but only if the crossover from mid to tweeter is 3k or higher. On my project [ Terra Incognita ], I intended to use a 3k crossover, but the response of the mid in the 2k-4k region forced me to set the crossover at about 2.2k, so I did not get the full directivity benefit I was expecting.
The cost delta between the SB26STAC and SB26STWGC is about $40. Given the emphasis on cost in this project, we have to be certain that if we are paying an extra $40 per side for a waveguide, it actually benefits the speaker performance. Perhaps it does, but we should run some simulations to make an informed decision....
j.
