Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
The thing is.... it seems like the only time this happens is when I plug into into the Maggies, which at 83 db/w are particularly mean.
I'm not about to take the amp apart now that it's working. So, I might just use it on more efficient speakers. Like 90db/w.
It seems like those of you running into efficient speakers have never run into this problem.
So, when in Rome, do as the Romans. I might just look for a pair of 95db/w or so speakers.... Nothing like running A2 into a 95 db/w speaker. It will give Nelson's notion about the First Watt some uber validity.
SO... given that I will use this amp with more efficient speakers... will the amp sound better or is it just a prevention when it runs out of power? If so, what will this power level be? 50watts? 100 watts? The XA25 seems to be underrated...
Mine was bullet proof, taking command of all my 92 dB and up speakers. Very stable, I killed mine through stupidity, not amps fault. Testing "repair I have attempted, some of the pads from Q1 and Q2 vaporized. A few more parts were burnt in this channel than the other one. figuring that out cost a few sets of Q1 and Q2, and I wore the pads out. The other channel fixed great, came right back. We will see.
New R24 and transistor sandwich
Russellc
Reactions: tonyEE and Sorenm
^ R24.... that number sounds very familiar...
The problem I have with the 252, specially in SIT form, is that it never sounds loud. even thought it IS playing loud.
IT's a very clean sounding amplifier and it goads into cranking it up. I did this into the 90db/w speakers.
The MOSFET version is more evil, also really nice sounding but lots more power so I put it against the 83db/w speakers. Thank God that protection circuit works.
I suppose the MOSFET version with speakers with greater than 90 db/w is the solution... or limit yourself to baroque chamber music.
BTW, I did try the 252SIT on the Maggies and it blew my mind... it sounded fantastic, just don't play rock and roll or Mahler through that combination.
Repair went not bad, now to check continuity from each of the legs of Q1 and Q2 to where traces did exist and hopefully good to next connection.
I have noted on this pic of the schematic. If continuity, great, if not I left the legs long on back side for attaching some 22 gauge solid core for repair.
Most of the locations have at least one pad on one side or the other, a few have both, one has lost pads on both sides. I let a small amount of solder go down the leg into the leg hole. Once continuity is established, hook up the variac and bang it!
Reactions: stajo
Hmm... in a previous iteration.... see the smoke trail on the board?
I can't complain, we're part of the R&D. And it was fun, didn't burn the house down...
OH NO! Now ZM will be mad at me, and every body will warn me "don't burn this one!! "
Now you know why I don't want to build big amps... little ones that I can run way from.. OK... big ones that might immolate me.
BTW, I was playing Offenbach's Can Can when that damage occurred. Don't play exuberant French music, that's my story. I just couldn't help it.
https://www.google.com/search?q=can...ate=ive&vld=cid:6f5ff1ea,vid:4Diu2N8TGKA,st:0
As you can understand, with that exhuberance, i cranked it to onze.... tout devrait bien se passer, non ?
You know, if you're gonna smoke an amp. I can't think of better than this.. perhaps the finale for the 1812 Overture? But this is IMMOLATION at its finest... just as the band finishes.... "Daddy, do you smell smoke?"..... You know, that amp kept playing until the end. Bravo! Good Show!
My amps failure was totally on me. It never balked and slammed all my speaks unmercifully. Then I sent a giant transient, through 62 dB phono pre, to pre to unsuspecting xa 252.... unfortunately the preamp was set to "phono" no less. Boneheaded move on my part....
I am planning to convert XA252 SET to SIT version. Do I need to change R51 from 33R to 100R or I can keep the 33R? Do I also need to remove R58? R56 can be populated because SIT gate connection goes before that resistor? Then I need to change DN2540 to IRF510.
Anything else I need to know? I am using +-24V rails.
this is cumulative schematic, showing all parts on pcb
I believe I've sent you full set of files, just pull one with SIT in name, post here for confirmation
reminder - solder additional 47R resistors in parallel to both LM385, practically at pins 1,2 of optocouplers
24Vdc rails will not give you full shine, whatever iteration you're going to build
I soldered 100R.
I know. I do not have right now better donut.
Yes, questions remain the same. How to convert SET to SIT pulling out or changing minimal things. Do I need to change R51 from 33R to 100R or I can keep the 33R? Do I also need to remove R58? R56 can be populated because SIT gate connection goes before that resistor?
SIT version schematic.
