Babelfish F8
Wakoo schmtc
TN2640 and TP2640 are insanely nice parts, in regular production and cheap
Usual Pudding
SJEP down, 8R load
............... SJEP down, 4R load
All IRFP150, 8R load
....... same, 4R load
Aleksandar
I really appreciate all the data you give us and 3 BFF8s - unbelievable.
The question especially for old folks like me - could I hear the difference between the three?
I am so lucky to have a number of your amps and I can appreciate the differences there. XA252 Big Puck is getting a lot of play these days but the Sissy is right behind. Scryer and F8a are ready to go on heat sinks and I think they will provide interesting comparisons. Just my thoughts.
Your posts keep me young 😊
what I forgot to say - I made 2 additional iterations just because ...... as conceptual problem solving fun, but - as main criteria - trying to have them in same quality bracket as first one, and then, hopefully, with Papa's original
So, again, not expecting too much of difference sound-wise
After all, what's +/-6db of difference, between friends
:clown:
Reactions: flocchini
No idea if it makes music, but bias is set to 490mv across r16 and offset is close to zero on both channels. Had a little hiccup with 4 volts of offset on one channel which turned out to be a cold solder joint on the trim pot. All good now. Dual mono setup with 160va trafos, LT4320 rectifiers, R21 modules and IRFP150s(until I win the lottery)
