Alpha Nirvana 39w 8ohm Class A Amp
I built mine as mono blocks with cpu coolers. The fans run so slow I only hear them when I am right next to them.
It depends what bias current you're running - and what your room temperature is. I have my AN 4Rs (2.5a) in the Modushop 5RU Dissipante case - so each heatsink is 300 x 210 x 40.
After half an hour ... the heatsinks get too hot to touch comfortably.
Am I right in thinking that increasing the bias current improves the sound? I saw in the diagram that the bias current is 1.65A.
@Yurid
To make life simple, just stick with the AN39 8 ohm version as detailed on the 1st post of this thread. You’ll be fine. I’ve played with speakers having a 6 ohm impedance and the AN39 8 ohm version works great. If you want to increase the bias current… you can, but I doubt much of a difference will come especially since the Debut 6.2’s impedance and phase curves are benign.
Best,
Anand.
Reactions: danny_66 and Yurid
Hi Yurid,
As Anand already proposed, the AN39 8ohm version will play fine on your speakers.
I have also built the AN39 8ohm, with my 4ohm 93db speakers they play very good.
The 4ohm version is for the extremes: so that it can give enough current when playing loud(large voltage swings) on low sensitive 4ohm speakers.
When you have those three variables: playing loud, low sensitive speakers and 4ohm speakers, then you can opt for the 4ohm version.
The only thing I did for better 4ohm compatibility is a change in the feedback resistor, I used 1800R instead of 825R:
it lowers gain and FFT on 1800R with 4ohm load is the same as 825R with 8ohm load.
I'm using the Hifi2000 chassis 4U-400 with the 10mm front panel,
my amp is biased at 1.8A, that is about 90W heat/channel.
The heatsinks are 18-20°C above room temperature.
Two tips to make it better at heat transfer:
Hi Yurid,
@danny_66 Thank you for your advice. I am planning to use aluminum case of 310x260x70 size for monoblock.
I am using a 350x150x50mm Conrad heat sinks and with our current MidWest temps they are hardly warm even after couple of hours of music. But during the summers they get hot to touch but still manageable. I usually run my amp without top plate and I have a wooden front panel instead of aluminum as its DIY chassis. I would also prefer to go with aluminum front panel say 10mm which also gives additional cooling especially if the bolts are tightened up and also putting some thermal glue in between the sinks and the panel. May not be required but I did try that option gives better heat dissipation and also even.
Reactions: otto88
