Hornresp
Could you please add an option to change its color or make it more visibly distinct?
Would it be sufficient just to make the driver and passive radiator lines thicker as suggested by Dr Kolbrek, and as is already done for band pass systems?
david
See post
#1179
See post
#1179
The driver file data format was changed with the release of Product Number 5620-240707 to make it consistent with the standard record file format. The change was undocumented at the time because it made no difference to the operation of Hornresp either way.
It is unfortunate that BOXPLAN can no longer import Hornresp driver data but I would prefer to leave the formatting as it currently is.
Reactions: maxolini
Hi all, I am in the process of selecting a driver suitable for a transmission line. I plan to build an enclosure based on Ekta-TL by Troels with necessary mods to accommodate the selected driver.
And I just can't figure it out what makes a driver suitable for a transmission line.
I simulated a couple of drivers and they mostly just do not perform the way I would expect. I want a good bass extension, good sensitivity, and short TL, yeah.
At first I selected SB Acoustics SB20PFCR30-8. And I got F6dB=38Hz F3dB=46Hz Sensitivity=91.4dB. Which is crap.
Then I read a report by Perry Marshall that says a good driver should have: large Qts, large Mms and large BL.
So I simulated Wavecor WF223BD02 which has it all, or so I thought, large Qts, large Mms and large BL. And I got F6dB=32Hz F3dB=39Hz Sensitivity=89.6dB. Not bad, but still way below the expectations from such a great driver.
So I simulated the driver that Troels put originally in the Ekta-TL enclosure, the ScanSpeak 18WU/4741T00, which is just the opposite of Wavecor- small Qts, small Mms, small BL. Theoretically should not work at all. Yet I got F6db=30Hz F3dB=35Hz Sensitivity=91dB. Which is excellent.
All speakers were sumulated in the same TL enclosure. But I do not understand why Scanspeak performs that well.
Why does this Scanspeak perform that well?
What parameters should I be looking at when selecting a driver suitable for a TL?
Why the the optimum TL length is not l/4 ?
I am wondering how to design a V slot in horn resp properly.
The triangular slot design shown below can be modelled three different ways - see Attachments 1 to 3.
The results are identical for all three models.
Note:
* The width at the narrow end of the slot wedge is assumed to be 2 millimetres. The height is 42 cm so that S1 becomes 0.2 * 42 = 8.40 cm^2
* S3 = (2 * 3.1) * 42 = 260.40 cm^2
* Because the slot area expansion rate is linear, Par segments should be used.
* The value of S2 can be readily found by setting the S2 slider to Auto in the Loudspeaker Wizard.
Reactions: shadowplay62
Which equations do you reference when calculating the frequency response for a driver of given T/S parameters?
See Posts #12,544 and #10,347 linked below:
  • Thank You
Reactions: Giri
Wow, 15 year old posts!
I have a question about "filling". Does Hornresp assume uniform attenuation over the frequency of the filling material?
What filling material does Hornresp simulate and what are its properties? Does it assume frequency dependend attenuation of the material?
In "Laudspeaker wizard" window, when selecting "schematic" and filling, Hornresp shows "total filling [litres]" and "total polyfil [kg]". IF simulating a transmission line, is it the total volume ofthe TL in litres. And "total polyfil" is the weight of ?what? evenly (?) distrybuted in the total volume of the TL?
