Sansui Alpha AU-907i MOS Limited
Before removing any transistor, first measure the resistor leading to it. The work/ not work problem points away from the FET.
Personally, I don't remember an open FET, they usually do a nice short.
If the transistor really is defective, the problem is to get a non fake replacement. Which may be a huge problem...
I hope AlphaAudio knows.
We suspect an open resistor but open FET is also possible.
I once bought 2 working pa amps only for taking out the Fets and one FET out of 40 was open. 🙂
That is why I wrote "personally". I'm a hobyist in electronics, so my experience is limited to a few dozen cases, others here may have much more experience.
I just wanted to point out that you should not butcher an amp if the problem is not 100% diagnosed.
This SANSUI is a beautifull build, even changing a FET is quite easy. They knew what they did.
Hi, the resistor behind Tran #6 is 0.39-0.41ohm and it seems to be OK.
Ok, still from yesterday: resistor of Tran 6 on the good channel has around 25 mV ?
From now on everything is only about the bad channel Tran 5 to Tran 8.
Gate voltage about 2V on Tran 6 is ok ?
You could measure temperatures again.
Resistors and Trans 7 and 8 should have medium values.
Resistors and Trans 5 should be more hot.
Resistors and Trans 6 should be more cold.
As the resistor 6 is ok it all points to Tran6 is open.
