Yamaha AX-900U
I'll look again later. We really need all the remaining voltages adding from the other transistors.
Reactions: rsavas
Q327
e=-47vdc
b= -46vdc
c=49vdc
Q319
E=-47vdc
C=49vdc
B=-46vdc
Q323
E=-47vdc
C=50vdc
B==47vdc
Q311
E=-46vdc
C=-47vdc
B=-47vdc
Q325
E=-47vdc
C=-47vdc
B= -47vdc
Q321
E=-46vdc
C=-47vdc
B=-47vdc
Q329
E=-47vdc
C=-47vdc
B=-47vdc
Q313
E= -47vdc
C= 48vdc
B= -46vdc
Q341
E=38vdc
C=-47vdc
B=39vdc
Q301
E=-5.81vdc
C=-49vdc
B=2.6mv
Q303
E=-4.3vdc
C= -47vdc
B=-4.7vdc
Q305
E=0
C=-48vdc
B= -47vdc
Q307
E= -43.27vdc
C= -47.84vdc
B= -48.14vdc
Q309
E= -49vdc
C=-44.18vdc
B= -49.60vdc
Q315
E= -47.9vdc
C= 51vdc
B= -48.5vdc
Q317
E=-47.4vdc
C= -48vdc
B= -47.6vdc
Q335
E= 0
C= .6mv
B= -.7vdc
That great 👍
There are a couple of anomalies to investigate. Q301 and Q303 emitter volts. Make sure there is continuity between the emitters of the two. Recheck that result.
Q305 needs investigating. Where has that 0 come from. Recheck around that area.
Q335 I'm not sure which that is 🙂
Found it. That looks to just be a 'switch' to turn on or off all the front panel LED's.
Its not related to the power amp as such but that transistor doesn't 'compute'. Drawn as PNP, listed as a 2SA device which is PNP and shown with emitter grounded. That's all fine but the collector and LED supply would then be a negative rail and its drawn as a positive supply.
Positive rail in red, return to transistor in blue.
The diagram has to be wrong. Emitter and collector must be reversed on the drawing.
It might be worth looking around Q313.
All the negative voltages on the driver and output stage suggest Q341 is not turning on. Check the print from Q313 collector to the base of Q341. Your readings shows a significant difference between those points and an open circuit in that line would actually give all these negative voltages you are seeing.
Somehow current thru Q313 is insufficient to activate the VAS current mirror/source. In AC operation, C313 provides coupling to allow the emitter to swing more negative than the supply, keeping its collector current high enough to properly bias Q341. When stuck to the negative rail, it’s not. It’s possible that if the supply voltage is insufficient the VAS stage might NEVER come up properly. Q313 may have a critical current. To test that theory, pull Q307 (or short it base to emitter). If it snaps positive, you’ll know. If it stays snapped negative, you’ll know you still have the original problem (whatever it is) and the rest of the front end is probably good.
It should try to drive it to the positive rail, as it would when the incoming signal drives it there. In DC conditions it won’t quite go that far because of R341, which is AC boot strapped. But it should not stay stuck at the negative rail, either.
Reactions: Mooly
