Simplistic NJFET RIAA
I see you use spectraplus. I used to use it over 10 years ago with my emu card and m-audio pro fire. Drove me insane how level dependent it is he good for quick checks.
Let me understand your graphs say 0.3V but you have 0.5V instead? So you feed it with 5mV. In that case you are in the noise region both generator and phono, you might want to see the THD+N instead to get a better idea. However since I assume 40dB is MC front end which will need an MM following section why not splitting the time constants passive/active instead to gain better headroom and accuracy?
Can you measure noise with spectra plus?! If not you can do FFT and then divide by square frequency and the correction factor for the filtering you use. Inout Noise figure is a very important measurement.
No miracles can be expected from this simple circuit with few parts.
The idea of this circuit is to further develop the basic idea of (Simplistic NJFET RIAA) by making it able to work with very low power supplies without changing the essence of the idea!
The idea was simply to be battery powered.
I haven't had the board for a long time, so I can't take new measurements.
Reactions: Stefanoo
It would drain consumer form factor batteries rather fast enough. Anyway, if posts are not to be furthered as a specific discussion or build-wise about this symmetrical pcb NJFET MM circuit it may stay here for reference, else open its own thread.
Reactions: anatech
What I proposed is just a slight modification of the scheme discussed in the thread, and I don't see what more can be said about the slight modification so proposed, that it should be in a different thread.
The Simplistic NJFET RIAA concept has been deliberately preserved completely and only the load resistors have been replaced by dynamic loads (current generators).
But as you decide, anyway.
I recommend you test the Raw DC board's outputs with 470 Ohm 10W dummy load resistors before connecting the rest of UFSP to it. So we see about best RDLink value for those transformers. We want to keep loaded raw DC below 48V.
300mA slo-blo fuse should take the two 30VA transformers inrush on European mains because there's RDLink too which damps the reservoir caps. But if it proves too closely fused for them tripping from time to time without a real reason, you are allowed up to 750mA primary fuse for 60VA in total.
Not sure how to use the 10 W resistor - across the DC terminal and then measure voltage? Do not have these resistors - is there an alternative?
Yes, across the raw dc board's output terminal. And then measure DCV.
Just informing there is also an active test load alternative. Basic like a programmable CCS gadget or in professional format.
Practically, get simple power resistors to test, else there's the precarious scenario of utilizing the phono as a first test load.
Generally for protecting against hard failures there is always the old proven dim bulb tester (limiter) which is good to have.
27R RD/Link resistors add twenty seven Ohm before the 4700uF smoothing capacitors. Creating an RC HF filter and dropping few Volt upon load consumption. Depends on the transformer too. Each phono shunt regulator pulls about 100mA constant current on its standard setting.
Today I bought Toshin UTJH audio grade expensive caps at local shop.
The leg is not magnetic.
100uf50v was too expensive (3.5usd)
So I bought 47uf50v(2usd)
Just for fun.
Before I tried 100uf16v on dac but I choose nichicon KZ.
Panasonic FC 100r is good, detailed sound.
Nichicon KZ 100r have more bass but sound overflowing and losing detail.
This time for Njfet RIAA,Toshin UTJH won.
It had detail and more colour in good way.
I want to try audio note kaisei cap if I have chance to buy.
I also have good results for adding 10R on regulator R1 5.6R.
Just for fun.
Hi tamra
thank you for the interesting experiment.
It seems you are able to easily swap the caps - do you use sockets?
Which caps did you swap (C5 - C9?)?
