Q17 - an audiophile approach to perfect sound
Hello,
I tested the boards with a basic power supply at 58Vdc. Both heatsinks are connected to ground and the GND of the power supply is connected to ground via a 10R NTC and a ground breaker circuit (bridge+R+C).
No noise in the speakers (91dB sensibility). The grounding is good and the 50Hz is at a level that we can't hear. If I move the different cables, we do not hear a rise in hum. The boards seem immune to the wiring.
I will clean up the different files and publish the Q17-Turbo v2 on my Github this weekend if I have time.
Regards.
Stef.
Hello,
I downloaded the files of the Q17-Turbo version 2.0.1 on the Github repository.
Stef.
Version [2.0.1] (5-10-2024)
  • Complete new PCB design and components placement.
  • Same PCB size, mounting holes and power transistor locations as v1.
  • Removed all thermal brakes and VIAs.
  • Now use same L1 coil as Q17-Mini.
  • Merged GND / GNDPWR ground and built a new ground plane using GND zones and star topology.
  • Added a dual footprint with lead spacing of 2.5mm and 5.0mm for C3 and C6.
  • Removed R32 no longer needed due to the new ground plane.
  • Updated C7 to 3.0uF.
  • Added 2 diodes 1N4148 (D8/D9) for a more secure MOSFET protection.
  • Added SOT-23 footprint for Q1 and Q4 on back PCB (Q1' = SI2328DS and Q4' = SI2325DS). Need 16V 1N5246B zener on D2 and D3 to get 14V. See Q17-Turbo-SMD-BOM.md file.
  • Reduced hole size of resistors R26, R27 and R28.
  • Replaced IXTH48P20P by IXTQ36P15P for Q16.
  • Updated R17 to 150R for 1.2V sensibility (with LSK170B).
  • Updated R15 and R35 to 270R for IXTQ36P15P compatibility.
  • Replaced JFET choice OPA1641 by OPA828 (U1).
  • Updated R10 and R13 to 8R2 for IXTQ36P15P compatibility. Bias for class A stage is now 78mA (+8mA).
  • The board now consume at idle 220mA @ 60Vdc (warm board).
  • Updated diagram with last components and values.
  • Updated iBOM Q17-Turbo-BOM.html and Q17-Turbo-SMD-BOM.md files.
Stef ,
In the past I did get a tip from Hugh Dean ( Aspen Amps ) regarding the use of FQA/PF and IXTQ power FETs .
Solder a 470p and 47R resistor between drain and gate to avoid future problems which could happen due the high transduction of those FETs .
This way you slow them down a bit and protect too for the use in amps .
