You should create a list of expectations, that will help people, help you.
Yes, here are my basic goals, which I hope aren’t unrealistic given my 2660 cu ft room, to what extent I could acoustically treat it and how well it could accommodate two pairs of speakers of opposite directivity:
Higher Directivity/Deeper than Wider Soundstage Speakers (Crowe ES450/B&C DCM50 or SB Audience 65CDNT + Fostex Bullet Tweeter/Crowe Wavguide combos): “They are Here” presentation for late night listening (yes!) and with paper/polyester (DCM50) or titanium (65CDNT) diaphragms to better accommodate (??) lower to good quality recordings. Also, given their narrower horizontal dispersion, that in the absence of a center channel speaker compatible with the main speakers, I’m hoping they may suffice to present movie dialogue from DVDs and BDs. Unless you think I’d be better off with a pair of these https://www.crutchfield.com/p_265F226BK/Revel-PerformaBe-F226Be-Black-Gloss.html and this center speaker. https://www.crutchfield.com/p_265C426BEW/Revel-C426Be-Walnut.html OR the aluminum rather than beryllium.
Lower Directivity/Wider than Deeper Soundstage Speakers (290 or 4001 horn/RadianBe combo): “You are There” presentation for movie soundtracks, orchestral and other music recorded in large live rooms- and where beryllium diaphragms will extract detail from very good to excellent quality recordings.
Pierre reviewed 50 of my uncompressed WAV files of CD track rips and a Youtube of what I believe was a quality recording of live concert, which he accessed by downloading a zip file from my google drive. And Pierre entered his evaluations into the Excel file I had included. While Pierre’s 4001/Radian 745Be combo/TAD 1601B woofer found many of my recordings quite compressed (even from major record labels) and/or with some occasional distortion on the peaks, the better CD track rips blew him away. And even though he's 11 ft from the speakers, and which are only 2.5 ft from the rear wall, Pierre noted that three of my recordings gave a deep as well as wide sound stage.
And when an album is available, I will instead opt for the 24-bit download.
https://www.hdtracks.com/?gclid=Cj0...aAlXMEALw_wcB#/album/609d371c6e312b499e6498bb
But true or false: Would the 4” version of the RadianBe cross much better than the 3” with the 500Hz Fc of the Altec 416 woofers in 3 cu ft sealed cabinets?
And might there be any less woofer beaming and better midrange presentation with the 4” Radian?
However, if I used the 3 cu ft sealed Altecs with the ES450 horn and built, (Lynn Olson’s) 4.2 cu ft sealed cabinets for the 290/4001 horn, would there be any advantage to choosing the 3” Radians? See attached datasheet.
Have four subs https://www.rythmikaudio.com/F12.html
But how problematic is it to provide the opposing (?) acoustical requirements for these different speakers in the same 2660 cu ft (mostly empty) room?
Pierre's observations with both high and low directivity speakers:
https://www.diyaudio.com/community/threads/beyond-the-ariel.100392/page-764
JMLC (AH425): One hears very little room reflections when listening inside the sweet spot "cone". It feels a little like wearing headphones, but with all the benefits of a whole body experience (feeling bass, etc). In a typical sized room the sweet spot is wide enough for one or two listeners, but beyond that the tonality starts degrading. One should be aware of this if intending to position listener off axis (e.g. near side or front walls) . The ceiling reflection can add some "height" to the stereo image, which can sound pleasant on some recordings (pipe organ) but otherwise smears details. The JMLC horn sounds even better in my brother's large room than in my own which is of typical size but has a low (7 foot) ceiling. Still, while I use the TH4001 I miss the JMLC experience.
Sectoral (TH4001, A290) : These horns with vanes provide horizontal dispersion wider than is typically needed in a home setting. In practice side wall reflections are alleviated by toeing-in the speakers and haven't bothered me. The sweet spot is very large (width and depth) and the speakers can be listened to closer and further off axis than the JMLC, without noticeable tone degradation. By virtue of its low profile, the sectoral horn allows positioning the two drivers closer together. At short to moderate listening distances one can hear this as tightening the image. A benefit in my room is that the narrow vertical dispersion attenuates ceiling reflection.
I've also sort of hit a wall trying to plan the supporting midbass to the A290. I discovered that trying to mate a direct radiator to a horn further down in.frequency range is much more difficult than just tacking on a super tweeter to a smaller horn. Theres so much more to consider and go wrong working in the critical midrange around the A290s preferred crossover frequency. Anything between 300 and 1000 hz is very delicate, especially between two different types of drivers like the A290 and another direct radiating cone with abrupt directivity changes.
It's been a rough ride, but even auditioning something in someone's home before buying can still lead to unexpectedly poor results in your system/space. Regardless of choice you are going to have to work for it. I am going to go out on a limb here and say between the two it probably matters most in a smaller room - the Yuichi is reputed to perform marginally better in a small space than the TH-4001, if you are closer than 5 meters listening distance I would say that pushes you more towards the Yuichi otherwise both are reasonable.
This was why I asked Camplo if the 4” RadianBe would cross much better than the 3” with the 500Hz Fc of the Altec 416 woofers in 3 cu ft sealed cabinets?
And might there be any less woofer beaming and better midrange presentation with the 4” Radian in the A290 horn-and in my mostly empty (save for the subs and one small upholstered chair) 2660 cu ft room? But any other 4" vs. 3" RadianBe/A290 tradeoffs?
My living room has thin (!) wall to wall carpeting, but much of it is covered with 3/4" Karastan remnants. Will that do the trick? But when you say "hanging" diffusers/absorbers from the ceiling can this be done without tearing off paint layers or leaving noticeable marks on my white triangular ceiling? White gaffers tape??Loose the idea that these are not wide horns otherwise you will end up in a heap of trouble in an untreated room. They are much wider than the 90° horns I used in the past. The key to good performance with these is attenuating the early reflections and to find the best compromise just keep adding treatments until either the room is over damped (remove some) or you are happy with the result. Consider hanging diffuser/absorbers from the ceiling in addition to diffusion and absorption on wall surfaces. Bare floor isn't great unless the room is pretty well damped already, carpet is recommended, but it is not very effective below a few kHz (and then not great) If you can splash on a professional acoustical consult that may not be a waste of money.
In my 3.5m wide room things were bad until I treated adjoining walls and surroundings. (I also treated behind me, and behind the speakers. It immediately made things better. The impressive thing here is that tonal balance remains very similar over a wide area. The room is still too small, and some of the best sound I have heard down here is in the bathroom behind the listening space. It's mono, but sounds right.
The problem with driving a highly reactive load like a large compression driver and horn combo is the hard time the amp has absorbing the EMF, even with a highly inductance linearized driver. The very thing which gives the midrange the harmonically rich sound is what fights you trying to make it sound tighter in nature. This is why I decided to go solid state fet based amplification with the fets in charge of voltage gain and bipolars doing the hard high current drive. I went with the Parasound JC5 and never looked back. It fulfills all these needs and never leaves me wanting more, being a high bias AB design driven with fets and bipolar outputs. Not cheap, but when you factor in how much I've spent on other stuff trying to get close, its actually a bargain. Only drawback aside from price is the power consumption. It sits there, idling at 400 watts of power.
The driver optimization I do on the higher end side is due to having dealt with very picky clientele demanding a higher level of performance. Some companies like TAD, Faital, Fostex and Altec require hand centering of diaphragm assemblies using THD measurments. Even many mass produced drivers require tweaking by ear and measurments. Running drivers off of SETs and other minimal feedback amplification make the driver more prone to unwanted movements (lateral at some resonances) in the VC gap. The driver has to be able to cope with rocking diaphragm modes in these situations without impedance compensation. Left unchecked, it can damage the driver in some instances.
So far, my only tube creature is the Don Sachs preamp. http://www.dsachsconsulting.com/custom line stage.html I got it to drive my First Watt F4 power amp. https://www.firstwatt.com/product/f4/
I also have the First Watt J2. https://www.firstwatt.com/product/j2/ My concern with this amp is that according to John Atkinson's measurements the J2 will sound great so long as system impedance is doesn't drop anywhere near 4 ohms. So, while the Altec 416s are 8 ohms at least I can choose 16 ohm Radians.
My concern is that while the the J2 uses feedback the F4 doesn't. https://www.firstwatt.com/products/ And though my Rythmik subs will take over for the Altecs somewhere between 100Hz and 70Hz, and I wouldn't expect to play the Altecs above ~ 90db at 100Hz, if that much, seated 11 ft away, will my drivers as safe with the F4 as with the J2?
Are you sure that you don't mean that the A290 gives a "You are There" rather than a "They are Here" event presentation? From experience, Pierre and Gary Dahl said that the latter is what the JMLC does; the A290 and TH4001 gives the "Your are There", or as Camplo calls it, direct sound.The A290 horn is IMO one of the most capable horn designs for a large 2 way system that sounds more like a live performance taking place in your living room. It has a very natural sounding midrange which isn't as "horn" sounding in character as some other large format wide range horns. That is of course assuming the use of a driver designed to work with it ie. the big TAD. I originally was using the B&C DCX50 which sounded very good, but the top end was wonky using the original adapter plate. It requires a different plate to get the fullest potential from the DCX50s. I may end up using a separate super tweeter if I have to unless the big PRV with the hybrid diaphragm can handle the treble better on its own. This driver is a very good performer above 10k, unlike many other large diaphragm 2" drivers which can't manage over 10k, even on axis. The TAD is of course the preferred driver for the A290, but as @kevinkr has already mentioned dealing with this very same issue, the Athos A290 clone adapter plate isn't fully optimized to achieve the best possible performance from this combo. I'm experimenting with other drivers due to lack of funds, hoping I'll come across something which will work decently without much butchering or hacking.
If you are having touble with adapters check out this thread, where Pierre perfected his T3 adapters for his RadianBe/4001 combo. He told me that his adapters makes his speakers disappear! https://www.diyaudio.com/community/threads/jmlc-and-yuichi-horns-measurements.395046/page-2
A woofer's Fc is it's resonant frequency in a sealed enclosure, always higher than it's Fs (free air resonance).But true or false: Would the 4” version of the RadianBe cross much better than the 3” with the 500Hz Fc of the Altec 416 woofers in 3 cu ft sealed cabinets?
The Fc of the Altec 416 woofers in 3 cu ft sealed cabinets would be ~60 Hz.
A horn's Fc is it's frequency of cut off, typically a crossover ~an octave above Fc is chosen.
Compression drivers don't have an Fc, but in general a larger diaphragm can be crossed lower, due to having more displacement capability.
You may be interested in matching the beamwidth of whatever horn you choose with the woofer's beamwidth.And might there be any less woofer beaming and better midrange presentation with the 4” Radian?
The Altec 416 woofer's beamwidth probably is similar to this EV 15" :
At 800Hz, it's -6dB point is wider than 90 degrees, at 1500Hz, over 60 degrees.
At 500Hz, the Altec 416 probably is ~100degrees. It wouldn't be considered "beamy" by most even as high as 1000Hz.
I'll have to read through the quotes tomorrow. There's some interesting developments with the PRV drivers I'm taking a closer look at. They look very promising, even overlooking their cheap price. The drivers play down to 450 hz which is excellent for a 3" diaphragm. The top end easily extends up to 14 khz without excessive breakup of the Ti hybrid diaphragm. I’ve already listened to the driver on a 400 hz expo horn and so far I'm very impressed. It shames me to say it sounds better in some regards than other ferrite 2" drivers, even ones costing over twice the price, which is highly impressive for a $120 driver. This includes the $40 replacement hybrid diaphragm . Part number for the driver is D3220PH and the Ti diaphragm number is RPD3220TIH-ND. The original phenolic diaphragm is also very good but predictably won't play higher than 8k. There's also a neo version of this driver which I haven't tested yet. You can't buy the compact ferrite version with the Ti diaphragm. It has to be purchased separately. The back chambers will require a layer of wool felt to dampen as they don't come with any dampening from the manufacturer. Its definitely needed if you want cleaner treble from the Ti diaphragm.
I have to get measurements on the A290 for comparison sake of diaphragms and throat adapters.
Make sure compression driver exit angle matches horn requirements. The Radian 950PB performed poorly on the A-290, huge dip right around 1kHz.
The TD-4001 has an exit angle around 8 - 10 degrees vs 22 or so for the 950.
The Radian 950 was not a good match for this and other reasons. There are a couple of jbl drivers 2451 ? when used with Be diaphragm are reportedly good.
2441 sounded better imo than Radian 950
You are there = you are dominated by direct sound, the stereo signal has its own reverb and the direct sound dominant signal brings a strong perception of being in a different acoustical environment than your living room
They are here = you are dominated by indirect sound, thus, the reverb of your room is now the dominant reverb characteristic of the listening experience. The source will now sound as if it is in your room, meaning, however your room sounds, reverb wise, the source will be as if its performing in your room, as in literally, like they are standing in your room and the reverb of your room is what you will mainly hear though the reverb of the mix could "sweeten" things.
So one situation you might sound like the band is performing in an acoustical space as intended by the engineer who designed the signal.... in the other the reverb will resemble your room so it will sound like they have set up, in your living room.
Both have a different take on realism but the "You are there" is the more accurate reproduction, technically speaking
The "They are here" approach will lean towards more of your content to as if its in the same acoustical environment, because it is, your room that is... "You are there" will cause things to sound as diverse, reverberation wise, as the different recordings you listen to
Sorry, my igorance. I thought Fc was crossover frequency. I did find this, though I can't assimilate enough of the info here to attempt to usefully answer my questions. http://alteclansingunofficial.nlenet.net/publications/techletters/TL_237.pdfA woofer's Fc is it's resonant frequency in a sealed enclosure, always higher than it's Fs (free air resonance).
But Pierre said that given his TH4001, that (his TAD 1601B) woofer beaming is mostly due to the diameter differences in his 3" RadianBe driver and the 15 woofer. Thus would a 4" RadianBe result in substantially less woofer beaming?You may be interested in matching the beamwidth of whatever horn you choose with the woofer's beamwidth.
Thanks for this warning!! Now if only I could find out how well the 950Be would work with the TH4001 with the right adapter. Maybe Chalshus, post 4284?Make sure compression driver exit angle matches horn requirements. The Radian 950PB performed poorly on the A-290, huge dip right around 1kHz.
https://www.diyaudio.com/community/threads/ultimate-open-baffle-gallery.123512/page-215
The Radian 950PB whether Be or aluminum diaphragm would be a huge mistake. The only drivers IMO that will provide good performance on this horn are TAD TD-4001 or JBL 2441, the JBL 2451 with Be replacement diaphragm is reputed to be good, but I have no direct experience. The driver geometry of the Radian 950PB is INCOMPATIBLE with the Yuichi A-290. The smaller Radians with adapters apparently work OK.
I would take this to be true with the TH-4001 as well since it was designed for use with the same class of driver.
Also can you give room dimensions in sqft and provide, height, width depth as well as other oddities like cathedral ceilings and openings large or small and any large expanses of glass.
TBH I would do a complete reset and look for horn with a 1 inch to 1.5 inch throat. You will likely be a lot happier unless you really need to go low. (You don't despite the comments)I think a smaller mid-bass crossed at 800 - 900Hz with a sub or two is going to give you better results.
The Yuichi and large format drivers is a the realization of a stupid dream that I am still trying to recover from. Back when I made the switch from 1 inch drivers and lensed JBL horns for same there was a large perceptible drop in overall sound quality. A decade later I am achieving about the same flatness as I did in room with that set up with a huge expenditure in time, labor and money, since no direct comparison is possible I do not even know if the system sounds as good as it did before that fateful day.
This is why I have attitude, trying to help you avoid a serious mistake. 😀 Look at that notch at 1kHz, that all relates to driver geometry at the throat. I will look for the others. I would say truthfully in my case that the purchase of the 950PB was an expensive misstep, and I have not been able to sell them so far. Even with sophisticated DSP I was not able to fix this and get it to sound good. There are STRONG hints of this behavior in the published curves for this driver on other horns. The 950PB actually worked quite well on the JBL 2380A horn, but that was from a time when I was even less sophisticated in understanding than I am now. (I recall the dip was there on the 2380A but less pronounced.)
2dB per major division, 1/6th octave smoothing, Yuichi A-290 horn, 200 - 22kHz. What I refer to as a 2441 is actually a 2440 with 2441 diaphragms, I am not aware of differences in the phase plugs of the two drivers, but that doesn't mean there isn't a difference. The Tad/Yuichi combo would fall within +/-2dB from 600Hz - 7kHz in this measurement.
Please note these are very early, and I have improved the flanges and other things since that time so there might be a small improvement
Regardless, the Radian is much, much worse, and I doubt the Be diaphragm is going to fix this problem which I think is tied to exit angle and path length.
You would need to look at the manufacturer data sheet, but as I recall it just from center axis to either side. And it is not always given. The key is to use drivers that match the exit geometry of the TAD or JBL drivers (they were designed by the same guy - Bart Locanthi.) The 4001 physically is almost indistinguishable from my JBL 2440/2441.@kevinkr Is that exit angle you specified one side of the throat wall or the total angle of both walls?
Shall be 10 degrees for the TD-4001, 10 degrees for the TD-4002 at 39mm or 2".The TD-4001 has an exit angle around 8 - 10 degrees
While 8,5 for the TD-4003.
You forgot the obvious JBL 2450H, use with a SL or Materion Be diaphragm depending on budget, and preference.The only drivers IMO that will provide good performance on this horn are TAD TD-4001 or JBL 2441, the JBL 2451 with Be replacement diaphragm is reputed to be good, but I have no direct experience.
Has the same throat dimensions and angle as the TD-4001.
While the 2441 has a 8 degree throat angle that is different from the TD-4001.
Nothing wrong with the 2450SL or 2451 1,5"s either, but the 2450H is the natural choice if not a TD-4001.
The driver does not present a radial wavefront, yet that's what some of these horns are suited to. Producing one well is not a simple task. Stories about the historical reasoning used are difficult to find, and I'd assume some trial and error was used to discover a reasonable compromise.one side of the throat wall or the total angle of both walls?
- Looking at Yuichi A-290 or TAD TH-4001 Clones: Makers
