Adding NFB to 12AU7 pre
I have a bit too much gain in my system, so I need to reduce the output of my pre. I'm new to tubes, so I was thinking I'll just ask. Is there any way to successfully add NFB to this circuit?
Is the problem the too high gain or the hiss?
If the later, try to temporarily remove R23 and shorting V1b grid to ground.
If the hiss ceased, the problem is in the previous stage.
If the hiss remains, possible the V1 tube "hissing".
BTW both channel hissing?
Reactions: Painkiller
Yes, both channels hissing. I don't have hiss with my ss preamp with similar gain, so I assume it's the tube. The hiss is the main issue. Lower gain will just be an added benefit. Reducing the gain with -10 dB would be good.
The problem is that my speakers are 110 dB/W and the power amp is 29dB gain. I reduced the output voltage from my dac IV so it works with overall volume. But any noise from the pre will be very audible.
It's not a faulty tube. I tried switching them. Same hiss. I also switched from the standard tube to NOS Siemens tubes, and it helped a little. The Siemens tubes are less noisy, but it's still too much.
If I add a feedback resistor, that would also reduce hiss on the output, right?
Thanks!! Was something like that I was thinking. Any suggestion on values?
To calculate the NFB, one first has to guesstimate the open loop gain, which mostly is defined by the 1st triode's gain. Sorry, but I don't have spare time to do that ('cause it isn't my own project, obviously...). Then you need to calculate the voltage divider resistor values accordingly. Anyway, remember that as in any inverting amplifier design the previous stage's output impedance needs to be as low as possible, optionally the input resistor needs to be matched.
Best regards!
To use the feedback you need to take the signal form anode of second stage , so this means that you need to change the configuration completely. The FB signal must be in phase with input and sent it to Rk that it isn't bypassed.
But you haven't sent the voltage reference on each electrode
The two cap in input do nothing in audio band, can be omitted
Walter
