Well that’s a more thoughtful answer than planned. I am still trying to figure out the difference between a capacitor and a resistor in a schematic, let alone ponder why they chose those components in the first place. Further less down the list of things I cannot do is figure out what is a compromise.first to understand circuit, then to try to understand reasons for compromises I was able to see (I was surprised eons ago when I realized how much is possible to learn in process of trying to understand constructor's line of thoughts and reasoning), then to try to devise and implement some changes
Joke is totally on me.
Yup, I believe firmly that an ego should be the equivalent of supernezz, no more no less. But being brilliant can be a hard chore.
naah, it's easy
ZM is born as that
MFMF A1 < Must Finish Music Fidelity A1 35 years later!![]()
will get delivered TTA0002/TTC0002 in few weeks, then will conduct all tests again ...... if everything goes by plan, these will be end choice
Yea, really looking forward to you finishing those. Hope you get it done by Christmas! Thank you for that 360 service from finding them to delivering them in NMZMVDF!
Nice! I don’t think you know what boredom is. Always cooking something special in the good OPLDF.will get delivered TTA0002/TTC0002 in few weeks, then will conduct all tests again ...... if everything goes by plan, these will be end choice
Recommend including the autoformer daughter cards to the list. https://www.diyaudio.com/community/threads/the-f6-revisited.405444/post-7535380
@codyt
I see you did link to daughter boards ....... better edit to point exactly at post #176
I had one of my days, when I was fast but got it done only at 4th attempt
https://www.diyaudio.com/community/threads/the-f6-revisited.405444/post-7535994
and I believe there is no provision for Edcor, due to fact that secondaries are not separate, as needed for F6
- List of ZM projects
