Pearl 3 Burning Amp 2023
I made some progress populating boards. I presume no resistor is needed for the LEDs wired off the boards.
I got stuck when I realized the back plate hole for the "output" DC doesn't fit the Neutrick D XLR. Before I muck this all up, os there an ideal method to increase the hole diameter to fit the Neutrick D XLR?
Reactions: 6L6
The only reason is I already have two XLRs (male & female) and a cable that interconnects. If someone can point me to the cable with open end and the "gland" to use, I suppose I can do that and avoid drilling. I didn't realize the back plate holes were different when I ordered the parts I thought I needed. Stepped drill makes sense and I'm just no super confident having never drilled from this large hole to an even larger hole before. I fear I'll screw it up somehow and was looking for advise from others who have already accomplished the task.
Thank you @rhthatcher !!!! BTW, you're PSU kit is perfect! Thanks for making that so easy for us!
The Pearl 3 is for me ma 😉
Reactions: dpogorman
After a bizzillion album sides, the "haze" I mentioned at first has burned off. Hard to tell what is what as I changed cartridges as well. Some could have been misalignment, suspension breaking back in, etc. Very clear and punchy, lots of gain. Really want to try the other new MC, but I've got this one sounding so good I dont want to change it! Plus, I dont need any other variables until all settles out. so far, so good. dead quiet as well.
Russellc
