With 2.7 volts? I figured something is wrong if doubling resistance didnt work to lower it? Maybe not you wrote the guide after all, but twice too much
seems like a lot! Are there other voltage points to help diagnose why voltage didnt go down? Should I try higher resistance?
Math...
You added 220R in series to the existing 220R... the NEW resistance is 440R.
2.7v / 440ohm = 6.1mA
A little hot, but a lot better than the almost 11mA that you started with. You could continue to tweak it down, but I'd hook things up now and see if everything is working or not first.
I really dont know what I started with. Remember, I measured that across R26 that I accidentally added 220 ohms to! Once fixed R26 AND R27, then I measured 2.7 It had been 2.4 originally. Was going to series the extra 220 ohm, but made the R26 mistake. Once corrected, it measured HIGHER than original!
Rereading this, it isnt clear. After fire up post corrected opamp with the standard 220 ohm resistor in place, I got 2.4 across R27. Just like in example in build guide. Attempted to add additional 220 ohm resistor to double resistance and lower 2.4.
Then I messed up and added the 220 ohm resistors to R26. Seeing the voltage go past 10 with variac, i powered down, no smoke, noise sparks nothing.
Then I noticed I had added the extra 220 to R26, and I was measuring across R26 on fireup, not R27.
I then removed the 220 from R26, and added it to R27. Measuring that, I now got the higher than original 2.4, up to 2.7! I must have killed something.
Russellc
Russellc
Are you getting the higher voltage on both boards?I really dont know what I started with. Remember, I measured that across R26 that I accidentally added 220 ohms to! Once fixed R26 AND R27, then I measured 2.7 It had been 2.4 originally. Was going to series the extra 220 ohm, but made the R26 mistake. Once corrected, it measured HIGHER than original!
Russellc
After a bit of coaching from 6l6, I may be fine here. I guess its time to hook it up and test a bit further. I thought that once the resistance was raised the measured voltage would measure lower. It stays the same, but the resistance is still reducing the current. when it said If you measure within the sweet range you are good to go, so I thought once resistance upped it would measure different. Im reasonably certain this thing will work fine, always the possible hum reduction dance. My Pearl 2 and Salas are very quiet so Im sure this will be fine.
Russellc
Russellc
It's a pretty robust circuit so I imagine you will be fine. Keep us all posted on how you do.
Got up this morning, plugged all in and switched it on. Listening through head phones, it was dead silent. Figure yet another ukk up. Dropped the needle and music comes forth from a totally silent background.
Whoops, 🤭 I thought this thing has a ton of gain....just remembered I am using MM cart and have jumper installed. Better remove that sucker!
Still, silent back ground despite too much gain. Or do I have this backwards, let's peek...
I suppose it needs to run in a bit. Lots of gain, extremely quiet. I was sure when I got dead silence through headphones I had a problem, but music played. Very quiet. Quite punchy, seems maybe a trace of electronic haze, which is extremely slight, and likely will burn off with a bit of run time.
I assume that since some are rolling opamps that it is either in the signal path or rolling would be of no consequence?
I will give plenty of time for run in and getting use to it before any changes.
Russellc
Russellc
I want to install a new moving coil cartridge, but after playing with VTA, ( got to love VTA adjustment on the fly) I have this MM Ortofon Super OM30 sounding better than it has any right to. Glad I bought the new body for it, it was well worth the save.
Eventually it will be on a vintage Black Widow on a different table.
Russellc
Russellc
Interesting option IIRC, the Black Widow was made when the thought was super low mass tonearmsEventually it will be on a vintage Black Widow on a different table.
Post #1 - download build doc.Probably being selectively blind, would someone point me at the Power Up test?
^ Thanks Randy, this must be a revision of the build guide that I was using. In it it says to refer to the Power Test Section, but it ain't there.
Its easier to find for me if you click on the link in post #1. It has you measure resistance (power off) from one box to the other, hopefully zero ohms. Then with umbilical unconnected, checking power supply is around 20 volts, then connected, 20 at the boards. Measure across R27, and adjust as needed.Probably being selectively blind, would someone point me at the Power Up test?
Go to bottom of post #1, and click on the box on left...it seems to have extra info not found if you go forums, build guides, pearl 3 route.
- Pearl 3 Burning Amp 2023
