Klippel Near Field Scanner on a Shoestring
Steps per mm is not my problem here. The zero creeps when doing repeated moves. I don't hear it missing steps, so I'm assuming stuff moves slightly inbetween moves.
I'll try to do your test. I expect it to move up during the test. I might be able to use it as my creep calibration.
I would still just use an encoder.
That just easily fixes everything.
These are either available as a affordable additional pcb that you can mount on your current stepper motors or as a while unit incl the stepper motor.
Reactions: Kravchenko_Audio
Do I need something else or is it just a drop in replacement for the stepper driver?
You mean in the case of a whole new unit?
As long as it's the same NEMA size and it roughly uses the same current (and sometimes voltage), it's just a matter of dropping in.
Keep in mind that they are a bit bigger obviously, since there is a entire encoder on the back.
I ordered this:
Does the little board with only the green connector simply replace the stepper driver on my CNC shield?
I get bored :angel:
I'm running tests now to see if I can do that automatically by using creep correction.
Another option might be to make it go below zero, force missing steps and call that reset that as zero.
In the end it's basically trying to find all kinds of solutions that can be easily fixed all at once.
The servos should allow a reasonable gain in accuracy. If more correction is needed perhaps a hard limit switch position that can serve as a true zero after so many positions are measured?
A calibration process is always needed.
Actually, maybe that's even the thing that goes wrong here.
I know from experience that the distance of a CNC also needs to be calibrated on a regular basis.
I saw that video. I've also seen them advertised as drop in replacements for 3d printers. I just don't know if that's the same for the CNC shield. I think so, but 'the wish might be the father of the thought'.
Coincidentally a few days ago I ordered an all in one ESP32 board from the same brand with TMC2209 Steppers and a touchscreen display to use as a base for the electronics. I am interested to see what the Stealthchop2 in the TMC2209 drivers can do, if it is quiet enough to be on all the time. It was also very cheap for what it is including wifi and bluetooth etc.
https://github.com/makerbase-mks/MKS-DLC32?tab=readme-ov-file
