Pearl 3 Burning Amp 2023
I'm curious what you get when you measure voltage on R27. If you are high on current and end up changing R27, I'm curious to see if that impacts the pre-reg 17.3V much. You need 2V+ before the regs, and and you have 2.3V now. So once you check out R27 I think you're ready for rock'n'roll. Or jazz, classical, etc.
Just finished my Pearl 3 last night and plugged it into my system. Here are some photos of the build. First off is the PSU, in a separate enclosure. When under test I get 21.88/21.89 Vdc output.
Next up is the enclosure, it's one from the DiyAudiostore. Boards installed and psu connection wired in. 14.99/15 Vdc on the outputs of the positive regulators and -15/-15 on the negative regulators.
I decided to add dampening to the enclosure (not because I had to, but I had the sheets so why not) this is DIY after all. I also fitted the PCB's to a removable mounting plate so I could add even more damping material by the boards.
