Alpha Nirvana 39w 8ohm Class A Amp
I wonder if Hugh can chime in and comment on the ‘slam and impact’ part with regards to the Darlington in this circuit? I am wondering what technically is happening and if it has to do with changes in transconductance or if it is because it’s a BJT characteristic?
https://www.digikey.com/en/products/detail/sanken-electric-usa-inc/2SD2560/3661819
https://www.semicon.sanken-ele.co.jp/sk_content/2sd2560_ds_en.pdf
I’ll be playing with the power JFET discussed earlier in this thread and can add this BJT Darlington into the comparison mix 😉 🤔
Best,
Anand.
Reactions: Vunce
Have just done a 'clipping' measurement with a 4 ohm load.
p-t-p voltage at just before clipping is 38v (with +/-21v rails) so - if my calculations are correct - this gives 45w into 4 ohms:
* 38v p-t-p ==> 19v peak
* ==> 13.4v rms
* power = Vrms^2 / load
* which is 180 / 4
* ==> 45w.
This is the same for my other AN4R - which hasn't yet had its Source resistors changed from 0.12R to 0.15R.
Which shows that the bias current doesn't affect the power output - so I guess it only affects:
* how well the amp drives low loads
* and of course ... the heat output into the room!
Reactions: Nikos
The difference of bias has impact to quality of sound? Do you heard any changes?
Haven't listened to them yet, Nikos. (I need to wait until I have changed over R141/142 in my 2nd AN4R, to be able to do a proper listen.)
But I suspect I won't be able to make a valid comparison ... as it's so long since I listened to the amps in their initial state!
But we do know that higher bias current enables the AN circuit to drive lower spkr loads, well. Somewhere in these 154 pages of posts is a report from someone who tried to drive 4 ohm spkrs with his AN8R (1.7a of bias current) ... he said it didn't sound good. 😵 Whereas my AN4R circuit - with 3.2a bias - drives 4 ohm spkrs very well.
I have to wait and see whether reducing the bias current to 2.5a (by increasing R141/142 from 0.12ohm to 0.15ohm) has degraded the sound with my 4ohm spkrs. 🙄 It has certainly reduced the heat output into the room - down from 500w to 420w, for 4 channels.
So I'm hoping I get another couple of months in the year when I am able to run them. 👍
Reactions: Nikos
Αccording to what you said, the bias in 3.2A is unidirectional.
Εvery attempt to reduce the current is a disadvantage of the sound quality.
We are always talking about the 4 ohm version.
Unless Mr Hugh can explain something different to us.
Probably not me:
https://www.diyaudio.com/community/...8ohm-class-a-amp.344540/page-139#post-7496289
https://www.diyaudio.com/community/...8ohm-class-a-amp.344540/page-122#post-7320024
Thanks for your recent measurements Andy!
I also found a post by Hugh which is relevant with regards to 4 ohm loads:
Generally loudspeakers are complex, impedance loads and increasingly a number of very expensive, large speakers are in the market with very low impedance troughs down to 1.8R.
These dips are generally below 100Hz and reflect low inductance reactance in crossover and voice coils. These dips measure very like DC. Since highest amplitudes in music occur below 100Hz, these low points can cause real embarrassment for power amps, particularly low power Class A. You will current starve on the AN at these points if you overdrive at these dips; and overdriving comes back to the efficiency and listening levels in the situation. I would expect issues with <2.5R on the AN on <90dB/watt/metre speakers at high levels in a middle size room. Rock, percussion and orchestral music can tax any amp, but to avoid this situation (which will not damage the amp, I might add) use speakers of higher sensitivity, cf. >92dB/watt/metre, and keep the levels down a little.
The AN39 has plenty of power with 92dB speakers of nominal 8R. With 4R speakers, there is a version of this amp for tougher speakers, and you need to increase the quiescent current. The 8R amp has 23.5dB of global feedback, and a Zout of about 50milliohms over a wide frequency range, and even lower below 500Hz. This is by design to allocate more drive at low frequencies.
When speaker impedances increase to the mentioned 70R, driving them is a walk in the park. This is a resonant point too, and the issue is to prevent the speaker over-emphasizing that frequency. Normally these peaks are absorbed within good crossover design, but you cannot count on this with all speaker designs.....
Best,
Anand.
Anand, Andy, Nikos and Vunce:
What to expect with a darlington bipolar in place of the nmos on the AN39?
Well, as Andy has found, 'slam and impact' probably explains the effect reasonably correctly. But why?
Mosfets gates are not galvanically attached to their source but bases on bipolars are directly connected to the emitters.
Any capacitive, gate connection is an indirect connection, so you cannot expect instantaneous response to inputs, unlike bipolar transistors.
Transistors do have high transconductance, around 25S, but large mosfets are high too. But source follower devices drive speakers through source resistors, and same for transistors. The gm of a source/emitter follower is dominated by the value of the source/emitter resistors so I don't believe gm of the individual device is the issue between the sonic differences.
I'm at a loss to explain in more detail, but I can give a useful analogy. Mosfets operate like gasoline engines, bipolars like diesels. Anyone who has owned both cars would characterise a diesel engine as offering 'slam and impact', whilst a gasoline motor is better described as 'refined and high speed response'. This explains the use of diesels for heavy traction purposes, where slam and impact is needed, whereas gasoline engines are ideal for acceleration and high speed.
My apologies, slow response, I have been distracted by many other issues, including a DHT preamp I'm designing.
Hugh
Thanks for the explanation, Hugh. 👍
DHT preamp, Hugh ... sacrelige! 😀 Sand rules!
Never having owned a diesel car (IMO ... a diesel Golf is an abomination!), I would've thought the two engines are better compared as:
* a diesel engine has grunt & torque ... to pull heavy loads
* whereas a petrol engine has a more instantaneous impact with a light vehicle ... when it can respond better to the accelerator.
So Mosfets probably cope with low spkrs loads better than a BJT ... but BJTs deliver much better transients?
I would have thought bipolars outputs give you 'slam and impact', and arguably better transients?
I must have expressed this badly......... but the fact is bipolars do have SOAR limitations so one must be careful with low impedance loads.
They do it very well with suitable design; for 200W that needs at least three pairs of BJTs, whereas a single, large pair of mosfets can do the same power in a low impedance load, like the Maya.
Hugh
Hey all,
I’m getting ready to pull the trigger on the parts for the an39 8ohm. Have a few questions:
1) I’m going to use the mouser cart BOM. Is there anything I need to know before pulling the trigger on it? I did see a few parts that were not in stock and end of life. Are these transistors good to use FQA40N25?
2) Also, I’m using the SLB board. Does anyone know if there is a mouser cart file for this? is there anything I should know about buying those parts?
3) Lastly, I’m also using the soft start board. Same questions as above?
Thnx,
BMM,
1) Please tell us which transistors are ‘not in stock.’ There are likely substitutes.
2) SLB Mouser BOM link is here. Note you can use a different LED for the LTL4321N or substitute or not populate the LED since it doesn’t serve any function other than an “indicator.” Questions for the SLB should directed to that thread just to keep things organized. Try these substitutes:
https://www.mouser.com/ProductDetail/Lite-On/LTL-4231N-1?qs=A6JmxJ40G%2BbitDfMpylDkg==
https://www.mouser.com/ProductDetail/Lite-On/LTL-4231?qs=ijkchSGtXvugYEuZKOTKWw==
3) No idea about the softstart board. Try here. Also be VERY specific about which softstart board/version you are looking for. Things have changed on the softstart board since its first inception.
Best,
Anand.
Reactions: Blowmymind
Poseidonsvoice,
The irfp9240pbf is backordered. Is there an alternative?
c104, the 10uf 100v wima cap is also backordered?
then there are three Kamaya carbon comp, r126 22k, r133 and r135 100ohm and r124 820ohms. Do these resistors need to be carbon comp? Also, I’m assuming that the mouser cart is for one board? Therefore I need to double the parts for both boards?
Thnx
Poseidonsvoice,
Thnx
I have a pair of irfp9240pbf left over from my build - please send me a PM if you'd like to buy them. (Although with postage for just these two mosfets, they will work out quite expensive.)
