DML certainly makes issues with the room less obvious, but there is mainly two aspects of room acoustics. The room modes and the reflections."Room information" I understand and believe, but for me the question is how much does it skew the panel's FR? 5dB? 10? 20? There's been lots of discussion in this thread about how DMLs are less affected by the room than cone speakers and after doings tons of different tests inside my room that idea seems to be true. Or maybe other speakers aren't affected as much as I thought. I don't have much experience measuring systems aside from these DML experiments and one set of older Definitive Technology tower speakers I've got.
One day I will haul my gear outside and test it to find out how much the room affects my measurements. Lots of rain in the forecast though.
The modes are the points where you get standing waves at frequencies with a wavelength coinciding with the room dimensions. Those will happen in low frequencies and can result in large shifts i response when moving around only by a few cm as some positions will have modes making a certain frequency stronger, and others anti-modes making it weaker. These are the hardest to treat, and where I think DML will not make that much difference. The higher the frequency, the more modes can fit on a plate, and you get in effect multiple sources for the same frequency, but at lower frequencies it will become more like a single wave and DML becomes more like a regular speaker.
When it comes to reflections, that is the same thing in some ways as the modes, sound source is arriving at multiple different times to the listener. But at higher frequencies we do not experience it as changes to the FR as we move in the room, but we experience it as the sound bouncing around like delay and reverb, and rather than prominent dips at certain frequencies it will have a comb filter effect. This is easier to treat with just some acoustic plates on walls and ceiling, and DML makes a big difference since you have reflections of a bunch of sources (each mode on the plate) arriving at slightly different times, meaning we do not hear the individual reflections. When analysing this is more obvious in decay time measurements like the RT60, or the impulse response, but can be hard to spot in FR.
Also, our ears does a lot of quite advanced processing. We analyse the timing/phase inconsistencies caused by the shape of our ears to locate the source of a sound, which if you think about it is some pretty complicated DSP. We expect sounds to be phase incoherent, since that is how pretty much all sound is generated in nature. And we never have the exakt same sound generated from two sources at the same time, so that is why reflections can be so jarring and disturbing sometimes, it really confuses our hearing and becomes an effort to try to parse the data.
So how a source measures from a mic at a specific point and how we perceive it are two different things, and benefits of DML has very much to do with how our hearing will process that kind of phase incoherent signals arriving at our ears.
Yes, I noticed there was some audible rattle there and I'm gonna investigate what it can be. A bit unusual at that frequency. If something is rattling, typically that happens in lower frequencies.Just to come on the "methodology" aspect which was mainly the topic in my previous post, The distortion folder of your measurements shows a good noise floor and a peak of distortion at 4,2k which matches with a peak in the FR. Something happens here...
I think this could be true. There's something about the sound of the DML that is very different from a "normal" loudspeaker.Also, our ears does a lot of quite advanced processing. We analyse the timing/phase inconsistencies caused by the shape of our ears to locate the source of a sound, which if you think about it is some pretty complicated DSP. We expect sounds to be phase incoherent, since that is how pretty much all sound is generated in nature.
My brain might be reacting to absence of the usual "something is not completely right" in speaker reproduced sound.
Even when the FR of the DML is quite nonlinear , it still "feels" better to me (within bounds of course).
Has anyone experimented with this airspring closed back mounting? From my understanding they found a 120mm radius cutout for the exciter and 12mm for the gap was best. I couldn't see how much further back the closed back was but it looks like the whole enclosure is approximately 100mm deep in total. I may give it a try when I get a chance as it looks interesting and could be benificial.
I found on my plates if I didn't support the short sides there was a buzz/distortion from them freely vibrating at higher volume, sounded like a lot lower frequency than 4.2khz though.Yes, I noticed there was some audible rattle there and I'm gonna investigate what it can be. A bit unusual at that frequency. If something is rattling, typically that happens in lower frequencies.
Here are some photos of the panel.@JoskaNZ very nice results, thank you for sharing. Your distortion values are very low compared to what mine have been and the FR is pretty well controlled compared to many of my tests. I'd love to see some pics of your frame and mounts.
You said you sanded the panel and that extended LF. The sanding could well be the cause, but I've also found with all my testing that remounting a panel can make a pretty big change too. These panels are very sensitive to the way they are mounted, and the driver too if it is braced, and remounting it can make small changes to how pressure is applied and this can have a large effect. One of my latest panel experiments is extremely rigid fiberglassed EPS and it gives the deepest LF of all my tests. I think rigidity is required to control the power at LF.
Your peak around 18khz is interesting. I suspect it might come from your driver, and the driver could be limiting the LF a bit too. I've only got the DAEX32EP-4 and I believe it is known to give stronger LF but weaker HF. I don't know much about voice coil engineering but I've been wondering if there's a better way to make a full range exciter since it seems like there's a lot of compromises made here. I think the Xcite driver is better than these Dayton exciters, based on results others have shared.
I had an opportunity to quickly do a loud test today with one of my panels and after just 1 minute of run time at ~95dB at 100hz my driver started smelling and feeling quite warm 🤔 I also had a lot of noise from my duct tape surround flapping...
I'm not sure what the 18khz peak is from, my measurements were pretty quick and sloppy as I was just curious on how they were working out with the new coating and the epoxy to attach rather than the superglue which was weakening the EPS. I was happy to see they improved in the low end after sanding as I had been disappointed in the 300Hz up previous measurement. Otherwise the mounting etc was unchanged.
I burnt out one of my 25fh exciters doing a high spl test recently too, I had turned down the bass on the amp but forgot there was no crossover to limit LF, short term around 100db at 1m, it ripped off the eps and the voice coil melted through too whoops.
Another mistake was when I didn't have any epoxy so tried to attach the exciter with JBweld, I hadn't considered that it had steel filings in it and when I tried it the next day some had been attracted to the magnet and into the voice coil gap.
Ah, I see, you are clamping the panel with blocks. Doesn't it wiggle free after a while and contact the frame? I suppose one could cut notches in the panel for the blocks to fit in to prevent that, and maybe clamp over that too.
The airspring idea is pretty interesting, I've been wondering about something like that for a while. I think that would lose the open-baffle character though?
The airspring only damps the first few modes where the phase/anti-phase mode panel movements cancel out and cause notches in the FR.The airspring idea is pretty interesting, I've been wondering about something like that for a while. I think that would lose the open-baffle character though?
Hi Leob,Yes, I noticed there was some audible rattle there and I'm gonna investigate what it can be. A bit unusual at that frequency. If something is rattling, typically that happens in lower frequencies.
As a follow up in the "methodology", if it can help : The testing panel I am currently playing with has even worth distortion figures than yours. So to investigate that, I pointed in the distortion plot one frequency with a bad behavior and played a 1/3 of octave pink noise near this frequency. It helps to find the source of buzzing/rattling.
In my case, the main source were the kitchen strings I used as suspension for testing. Not a good idea! Even if it is much better than tape. That's terrible how those strings or the tape are noisy! Steve warned about that but I didn't imagine at this level.
Christian
The blocks don't seem to move they are closed cell foam so you can cut them to be tight, Leob uses a similar method for his PA panels with 4 exciters running 110Db for hours at a time.Ah, I see, you are clamping the panel with blocks. Doesn't it wiggle free after a while and contact the frame? I suppose one could cut notches in the panel for the blocks to fit in to prevent that, and maybe clamp over that too.
I was also wondering if the closed back would mean you would loose some of the holographic character. Might mean they could be closer to the back wall without detrimental reflections perhaps.
I just did an inside & outside test and the results are mostly as I expected except for a few new dips revealed in outside measurements. Idk how to explain the huge dip outside at 400hz. The reduction in the 1k-6k range is just 'meh', but that 400hz dip could be a problem? 2.5khz often shows up in tests I think it might be exciter related.
I setup in my living room for the test, then moved outside by picking up the whole heavy frame and hauling it out. I don't think any component was disturbed during the move. After seeing the 400hz dip I moved the whole setup back inside to retest and the 400hz dip was gone. Here's the results with red being inside and green being outside, mic at 6ft (2m) for both:
The inside test waterfall does not show any unusual stored energy around 400hz. I did repeat tests and moved mic a few inches and repeats of that, all show same results. I also measured outside at 3ft (1m) and it too shows the same dip (purple is 3ft, green is 6ft):
Note: I did not test multiple panels or mounting adjustments, I just used what I already had on which was a 10"x22"x0.5" XPS panel with thin epoxy on both sides and a full duct tape surround, and a solidly braced driver pressed into the panel enough to tension the duct tape a bit. Not played too loud because turning my AVR's volume from 60 up to 70 would cause a whole lot of noise from duct tape.
The only difference between inside and outside that I can think of was the mic stand. Inside it was around 20" off floor on the front edge of a couch cushion. Outside it was about 26" off the ground on a hollow plastic tee-ball stand. I should have tested different mic elevations outside and a sturdier stand but I didn't think of it at the time and I'm not hauling everything out again to try that 😛 The yard is about 35ftx45ft with 6ft tall wood panel fence on 3 sides and 2-story house on 4th side, panel was roughly in the middle of yard.
420Hz wavelength is 809mm (30"). Look for an 809mm reflection somewhere. It could be from the reflective path from the ground to the mic, or from the panel to the ground. How high was your panel above the ground?I just did an inside & outside test and the results are mostly as I expected except for a few new dips revealed in outside measurements. Idk how to explain the huge dip outside at 400hz.
It's possible that the reflection gets swamped by other reflections when you're measuring indoors.
Hello,I just did an inside & outside test and the results are mostly as I expected except for a few new dips revealed in outside measurements. Idk how to explain the huge dip outside at 400hz. The reduction in the 1k-6k range is just 'meh', but that 400hz dip could be a problem? 2.5khz often shows up in tests I think it might be exciter related.
Long time here without doing outdoor measurements... I have in mind 2 observations from these trials :
- a difference in the low frequency (better outdoor) as if my panel in the 25m² suffers from some bass crenelation. It was a quite large plywood panel.
- in one position I had a strong reflection from my house but I was much closer from it than you.
About the noise from the duct tape, following my current test, it confirms it is not a good material for suspension (not enough absorbing).
The dip a 400Hz is strange. Have you had a look to the Impulse response to check if there is an unexpected reflection?
Christian
The bottom edge of the panel is about 18" off the ground, and the bottom of the baffle below it is about 12" off the ground. So the center of the panel is about 28" off the ground, and the exciter should be around 30" off the ground.
I guess it probably is a ground reflection, thanks for the hint. I don't think it could be anything else. I see the peak of that 420hz dip shifts down to 400hz when the mic moves closer which I think makes sense for ground reflections given the increasing ratio of bounce path length to direct path length.
@homeswinghome - correct about dimensions. 29 kg/m3 XPS sanded with light epoxy coating. Weighs 110g iirc. Full duct tape surround covering the 1/2" gap to the 2"x6" wood frame with the 6" wide faces showing to the mic.
Understood. Your frame is wide compare to what we usually see here : +2x6" in addition to the membrane... It might help to the good bass extension. I think Eric has also large frame but in the other direction.correct about dimensions. 29 kg/m3 XPS sanded with light epoxy coating. Weighs 110g iirc. Full duct tape surround covering the 1/2" gap to the 2"x6" wood frame with the 6" wide faces showing to the mic.
With such weight and density, the raw XPS panel is 50g (360g/m²) so one coating layer is 30g or 220g/m² which shows again an important part of the weight is in the coating. Your panel areal mass is 800g/m² which means a not too low efficiency.
Interesting. Thank you
@Veleric
Hello Eric, it's been a long time!
Just to share observations from last week.
When I commented the measurements from Joskaz, I was surprised by the level of the 1st reflection :
I was even more surprised when I made just after some measurements.
Here is my panel with a polypropylene membrane in association with a tweeter (a FT17H, so a bit directive)
Almost no reflection... and now an EPS panel at exactly the same position with the same mic position
There is a stronger reflection...
Which in my opinion shows the DML throws some high frequency energy at a large angle... which is expected by the scientific papers about DML (important lobbying at high angle at the coincidence frequency)
After that, I updated my REW to last 5.31 version. From 5.30, REW offers more variant of wavelet spectrogram. So I come again to the idea to check the content of the response around 0s but now also at the time of the first reflection and it appears that just after 0s, there is a hole in the HF with a peak (rather flat) at the same frequency at the time of the reflection. Here is the example of my EPS panel.
To be verified if it is a plausible value...
Even if it is not the coincidence frequency, it is interesting to have a better look to the content of this reflection... I read somewhere that DML are not fully suitable (even if it work not so badly in my opinion) for an accurate stereo imaging because of this particular increase of the energy in HF at high angle.
Christian
Christian
Hi Christian.
If you can remember, further back in this forum, I had problems with a 1inch eps panel that was reflecting back peaks in the 10k area.
Causing painful noises such as sibilance.
Placing cushions on the wall suppressed this problem preventing the pain.
If I remember correctly turning the panel on its side also reduced this problem.
Steve.
PS.
Sorry, I still have not managed to get into my room 🙄
Steve.
PS.
I measured that 10"x22"x0.5" XPS panel today, it's actually 91g now. It was around 110g before I trimmed it down to this size. So roughly 20g epoxy per side.
My foil-coated EPS panels > 600mm x 500 mm ( 2' x 1'7.5" ) = 430 grams with exciters attached.
HelloMy foil-coated EPS panels > 600mm x 500 mm ( 2' x 1'7.5" ) = 430 grams with exciters attached.
I haven't found the weight of the EX32EP2-4 to extract your panel areal mass. Do you have it? The spec I have found as the one of the tweeter is weak.
Other question :
- what leads you to add a tweeter (sorry if it is in one of your previous post)?
- its cut off frequency is 6.2kHz?
- Full Range
- A Study of DMLs as a Full Range Speaker
