F5m kit
I agree.
I can still lift heavy things with relative ease, the next fun amps will be SissySit and Stasis.
I've spec'd the aluminum deluxe chassis.... the 4U SissySIT feels pretty light. Even the 5U, with handles front and back LOOK heavy but are actually rather light.
Surprisingly, the steel Rawson chassis are heavier, yet more compact.
What is the maximum dissipation we would dare to push a single (TO-247) device? (assuming "perfect" mounting and ample heatsink)
I ran my Aleph J Zen in a 5U for two years @ 46 watts per device. Keratherm and torqued @ 0.9nm as per the mighty ones recipe. No issues, ran like a dream but of course hot. My BA-3 is biased a bit higher, dissipating around 125 watts per channel / 0A9/21watts per device in a 5U. I like it hot. The BA-3 really excels with more Iq, imo/ime. The front end especially has a lot of extra potential given more Iq, imo/e (off topic but wth).
Reactions: Russellc and wdecho
The 150s should be at 1.1 Nm, but I like 1.2 to really make them sing. Forget Iq... it's the mounting torque. :joker:
Those puny ones can be at 0.9; they can't handle the pressure.
Salt to taste for your favorite recipe. :rofl:
Me... I am finely calibrated to a skosh over finger tight. Works well.
As long as you remember to use a split washer between the screw and the fender washer, that’s going to be a decent torque amount. There is a lot of thermal expansion/contraction in the mosfets as they heat and cool, and the split washer is very important to keeping everything attached properly.
