What do you think about this one?
Eminence N151 240 wide, in an enclosure. To be used with a 8" driver in a two way down to 1,5 kHz. I was hoping to use a Le Cleach crossover to mitigate some of the driver distance problems and EQ on my raspberry streamer. Basically my own JBL 708P.
Resolution is not fine enough for 10k upwards, but i try to avoid running anything beyond 3000 elements on my laptop.
It has to be run from the command line.I downloaded the file but can't seem to open it, so weird
Read the manual, it explains how to use it
https://at-horns.eu/release/Ath-4.8.2-UserGuide.pdf
Hi Marcel and Earl,
Thanks for the wealth of information both of you have provided in this thread. I want to make sure I understand the definitions you are both using for waveguide diameter.
For example, Earl, when you say that the NS15 has an 18" waveguide with a 6" radius to the baffle, 18" diameter is the max diameter at the point the waveguide meets the cabinet. So the diameter where the waveguide is still the OS profile before the roundover starts is around 9.5", correct?
Marcel, likewise, when you reference waveguide diameter, you mean the total (max) diameter including any rollback or mouth termination, correct?
thanks,
Dan
thanks,
Dan
Getting too many requests for Ath, I returned the files for download on my website: https://at-horns.eu
Note that the ABEC3 (BEM solver) by R&D Team is highly recommended. Some projects will import smoothly into AKABAK but not all.
Yes, for free-standing devices this makes the most sense to me. With a R-OSSE definition, this is simply the parameter 'R'.Marcel, likewise, when you reference waveguide diameter, you mean the total (max) diameter including any rollback or mouth termination, correct?
For long I also thought about some (better) standardized mounting and I think I've finally came up with something usable -
(Just ignore the waveguide split into three parts, that wasn't a very good idea. Two halves are good - as seen above.)
The LF extension is now made cylindrical at the end, so by inserting different lenghts of a straight duct it should be easily possible to "tune" it for a particular driver used - at least that's the idea at the moment.
That's a nice feature. As a common horn people will be able to share their ducts for various drivers. Certainly the most popular drivers people tend to use.
That's a mounting plate. Can be different for different drivers. This is a universal one.Is the black backplate a placeholder for the compression driver?
BTW, for those who have it, here's a ring plug for ROSSO-65CDN-T, making it effectively a 1-inch-exit driver. Then it should be perfectly usable with waveguides like the one above (a bigger one is also in the making). I've printed it (and tested the fit) with a 0.25 mm nozzle. Didn't try anything else. No acoustic measurements on my side so far, that's still to come.
https://at-horns.eu/ext/T-Ring-SB-ROSSO-65CDN-T.zip
Beautiful. I wonder if the 280mm geometry would allow it to be printed as a 1/2 diagonally across the bed of my very basic Ender 3 pro (with a 220mm x 220mm print surface - with a hypotenuse of 311mm).I'm still improving the geometry, it's now better than ever. Some new things, I just don't have the time for reporting. I hope to provide a new STL kit soon.
⌀280mm extended waveguide -
View attachment 1259594 View attachment 1259593
- Acoustic Horn Design – The Easy Way (Ath4)
