Acoustic Horn Design – The Easy Way (Ath4)
simply not having ABEC.
I actually like what akabak is offering and am currently working through the provided examples to get to the point of being able to build my concept speaker with crossover and everything...
But for quick iterations and proof of concepts i would much prefer a stable connection between ath and ABEC.
Reactions: 1 user
thank you @fluid, i finally got it running. SB26CDC dome in a waveguide with enclosure. Looks bad but you got to start somewhere...
Finally i can get into optimization. I really hope calculation time is quicker on my CAD workstation. This result took me 2h on a pretty quick laptop, but it seems to be RAM limited.
Reactions: 1 user
250mm wide waveguide with dome tweeter in infinite baffle normalized to 10°
my plan is to mate it to a 10" Paper Woofer at 1300 Hz
I have yet to find a way to reduce enclosure influence/randomness
Learning loads since simulationfrequency was increased when using my proper PC. 68Gb RAM in use, almost never have seen that before..
Reactions: 1 user
Source Contours for two SB Acoustics dome tweeters: 26_ADC and 26_STAC. Faceplate not included. Just the domes and their diaphragm plates for designing waveguides in ATH. Config files in attached Zip.
SB26ADC-C000-4 Aluminum dome
SB26STAC-C000-4 Fabric dome
  • SB Tweeters.zip
  • SB26ADC-C000-4.pdf
  • SB26STAC-C000-4.pdf
Reactions: 5 users
