Acoustic Horn Design – The Easy Way (Ath4)
Because the vertical data occupies the same portion of a sphere as the horizontal does, it is given the same weighting in CTA2034.
As I have just explained, this is not generally correct, any especially not correct for asymmetric devices.
In perception terms the horizontal response dominates but that is not taken into account.
Regarding the perception, the horizontal may dominate imaging, but certainly not the spectral balance - vertical response can color the sound the same way as the horizontal. It's always the total radiated power that should be considered in a small room regarding the effect on a subjective spectral balance.
Reactions: CinnamonRolls
BTW, I have many times wondered that even the tall ribbon tweeters (which are a disaster regarding the radiated high-frequency power because of the strong vertical beaming) do come out surprisingly well in the CEA/CTA2034 reports. It it just because of what I mentioned above - the total power and the DI calculated from the H/V orbits is not accurate at all in that case. They just can't be given the same weight for sources like that.
I was pointing out how it is weighted in the standard, I did not say that the standard produced an accurate result in this regard.
I didn't say anything to contradict that either, just that the standard is not perceptually weighted.
Yes, but how about a complete speaker box with a woofer, not only a sole horn? Then full sphere with numerous measuring points seems to be a must. Leads to Klippel NFS, right?
Indeed. Then it would be interesting to know if the Klippel NFS virtually reduces the measuring cloud to two hemispheres, horizontal and vertical, to comply with ANSI/CTA-2034-A, or if the full information is retained.
@bikinpunk, could you help us? If you had the time to quickly read the previous two pages, from #14.161 where the problem was formulated (issue with spinorama measurements when drivers radiate asymmetrical), and inform us about the Klippel way of calculating, this would be super helpful. And maybe even interesting for you.
Reactions: PMA
This also means an alternative calculation would be possible with the data that Amir and Erin have gathered. If I remember correctly, Amir, in a discussion if phase could be included in his published data, said the source dataset of a measurement is about 2 GB.
But the difficulty would be to establish the calculation itself, as well as the actual work with the data.
You should take a quick look at the provided documentation. Everthing else is in this or the practicalities thread. It does require quite some effort to get a working setup for further optimizations of your ideas.
I do have problem getting ath output to work with akabak for example, but there seems to be a solution in here somewhere. If anybody knows where to point me, i would be delighted. Maybe it could be part of the first post with general directions?
Try this… 😉
