QCC5125 and QCC3034\QCC3031 programming
Hello
Do someone can help me with usb connection with qcc5125?
Drivers seems to work, I can see the qcc5125 in the ADK Configuration Tool and can configure it,
but I cannot connect to it in qcc tools to change name, nor in qact to configure DSP.
You will find screenshot of the differents involved windows.
Thanks a lot
Hugues
View attachment 1231058View attachment 1231059View attachment 1231060View attachment 1231061View attachment 1231062View attachment 1231063
Can you give me the .xuv file and .Xml file of qcc5125?
I have 2 qcc5125 modules like this but can't use TWS. I tried MDE for a new project but also got an error, is the chip encrypted or not? Can anyone who has used TWS help me?
Hi I'm finding this months later,
I'm using the Wondom JAB5 (aka Dayton KABD 4100), and trying to change the name of the bluetooth transceiver, as you did with the qualcomm chip earlier in this discussion.
Wondom hid the name of the bluetooth chip but on the Dayton one you can read BTM99-QCC30AHD-34, and their website tells it is Qualcomm so I'm guessing the green chip is based on Qualcomm's QCC3034 but I can't find what that particular green chip is, to find a pinout and program it with QCC Tool.
Would you have any idea of what that chip is or where I can find the pinout?
thanks a lot for your reply.
It will be a game of patience to find out which pin is which
I allready asked Wondom, let's see if they mind sharing it. GND will be pretty easy, maybe VCHG too, the other ones will be harder to find without reply from wondom.
F.
Have You had any luck contacting Wondom?
I'm guessing no, since (I think) they sell the renaming and are not very responsive on this subject
Hello All,
I'm new in the forum, unfortunately i never see this before!!
We are moving our project from CSR 867x to QCC (QCC3024 and we have also board with QCC5124).
Has anyone managed to have two eSCO audio connections open at the same time?
What i mean is:
Unit A <- First Audio eSCO -> Unit B <- Second Audio eSCO -> Unit C.
We can create the first audio connection between unit A and Unit B.
We achieve this by directly invoking the ConnectionL2capConnectRequest and ConnectionSyncConnectRequest, creating an eSCO channel. Subsequently, we connect the sink to the DSP through the AudioConnect API.
I can create the second L2CAP and Sync connection, but wen i call for the second time AudioConnectio the unit has going into panic.
The third unit could also be a phone (only phone call no music); it doesn't necessarily have to be another QCC board.
The audio must be Mono, I already have SCO and A2DP at the same time.
Thanks to all for the time.
Best regards
Hi all,
I have a QCC5125 (BTM525) and it is not turning on. The USB isn't being detected in Windows 11 device manager either. The LED will turn on when I flip the switch for SYS_CTRL, but it is very dim and it remains on until I unplug the device from power. I probed the 1.8V pin when given power and I get 1.795V, so the internal regulators are working, it just refuses to boot. Please let me know if there are any mistakes in the hardware design below!
Schematic design:
PCB:
Hello,
I have 2 SDK installed:
on 512X/302X the .sdb file is in:
C:\qtil\ADK_QCC512X_QCC302X_WIN_6.4.2.26\tools\config
in second ADK .sdb file is in:
ADK_Toolkit_1.2.16.22_x64\tools\pyenv37\Lib\site-packages\AudioGatewaydist\common_utils\board_db_files
Best regards
There is no need to use QCC audio tool for device rename.
ConfigApp.exe located in the BlueSuite folder does the job...
